SkullV
Thunderbunny.....
Alright, I have my AWE boost guage installed in the vent pod and ready to get pushed back into the vent but the damn thing just will not work correctly. I have it wired up exactly as the manual states but I get no backlighting, the gauge goes crazy when I move the dimmer, and it re-sweeps when I turn off the headlight switch.
The manual specifies the following:
I know the connections are not the problem as I am getting the multimeter at the gauge harness plug right where it plugs into the gauge. Anyone have any idea what I need to do in order to get this gauge working properly? I would give AWE a call tomorrow but I'm sure they are closed.
- Red Gauge Wire to Purple/Black Harness Wire - Multimeter reads as Ignition switch on/off
- Green Gauge Wire to Gray Harness Wire - Multimeter reads as Headlight Switch On/Off (with dimmer)
- White Gauge Wire to Red/White Harness Wire - Multimeter reads as CONSTANT 12v+ (I am assuming this is the issue)
- Black Gauge Wire to Brown Harness Wire - Multimeter reads as Ground
