carmaster22
Has anyone made these work together?
I was reading through the thread about the Unitronic DV relocation kit and the rep from Uni didn't guarantee compatibility with any intakes except their own but said that any intake with a 3" diameter should fit.
When I saw that the Cobb intake was a 3" diameter, I thought there wouldn't be an issue.
Well...after trying to install both this weekend, I found the issue: the silicone coupling in the DV relocation kit is made for an intake pipe with a 90 degree bend going into the coupling. The Cobb intake piping is closer to a 45 degree angle so it won't fit into the Unitronic coupling.
I'm thinking the only solution is to have a custom silicone coupling made that has the offshoot for the DV relocation piping as well as the angle needed for the Cobb intake piping.
But I wanted to see if anyone here has a solution...anyone?
