Old 12-09-2015, 06:43 PM   #113
mk6_gti
FIA World Rally Car Newbie
Drives: 2010 GTI
Just had this done today. They replaced the upper timing chain cover gasket and some other gasket/seal. All paid for by my extended warranty. Yay.
mk6_gti is offline   Reply With Quote
Old 03-02-2016, 03:44 AM   #114
SuPeR GTi
SuPeR GTi's Avatar
Drives: 12' GTI MT
Noticing same issue here. Oil around timing chain cover and valave cover. Anyone happen to know of the tsb that takes care of this?
[AirLift Bags + V2] [Revo Stage 2] [SouthBend Stg2 Daily+SMFW] [EuroJet Catted DP] [Magnaflow CB] [Neuspeed PFlow] [NewSouth Boost Gauge] [APR Boost Tap] [ECS DogBone Mount] [R Led Tails] [Ed's HeadLights]
SuPeR GTi is offline   Reply With Quote
Old 04-26-2016, 10:35 PM   #115
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
ditto
carsfeverguy is offline   Reply With Quote
Old 06-21-2016, 09:32 PM   #116
Moore887
Drives: White 2 door golf. CMax Energi
I discovered mine was leaking while I was getting the timing chain tensioner replaced as a precaution on my 2010 with 70k which i just bought. Brought the car back to the dealer to have it replaced under the one month warranty and they sent it to the local VW dealership to be looked at. They called me later to say that it's to be expected with a car of that mileage and there's nothing they are going to do about it.
Moore887 is offline   Reply With Quote
Old 10-11-2016, 01:46 PM   #117
yuev87
Drives: '12 GTI Autobahn
Just had the valve cover gasket (or sealant) replaced at my dealer. I have 50k miles but the car is CPO until 57k miles. They gave me no trouble at all with fixing it under warranty.
yuev87 is offline   Reply With Quote
Old 10-11-2016, 02:32 PM   #118
corman1313
FIA GT Newbie
corman1313's Avatar
Drives: 13 CW GTI DE
I had my valve cover resealed about 2 months ago with 32k miles under warranty, if the dealership is cool and you have a good relationship with them they will do it out of warranty in my experience.
Sent from my SM-N920T using Tapatalk
corman1313 is offline   Reply With Quote
Old 02-13-2017, 05:06 PM   #119
zVp
Formula 5000 Champion
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Originally Posted by MKVI_noizsky View Post
Thats coming from the Upper timing chain cover just tight the 5 side bolts
Has this worked with people who has had the oily water pooling on top?
I am going to tightening the 5 side bolts (or at least the ones that are accessible to me) to see if this helps.
2012 DEEP BLACK PEARL GTI
DSG | APR Stage 1 | DriverGear Springs
zVp's Car Journal
zVp is offline   Reply With Quote
Old 02-19-2017, 03:06 PM   #120
matt9112
Newbie
Drives: 2010 jetta wolfsberg
first post so here goes
i have a 2010 jetta wolfsberg and after reading this entire thread i noticed my valve cover has oil residue in all the places discussed here. (around front cover seal and crank sensor)
so my question is this i have a CPO warranty for roughly 1500 more miles should i take this in eat the deductible and hopefully get a new seal and sensor?
compounding my concern is the fact that my car did have a PCV failure about a year ago. (entire unit was replaced)
for reference bone stock engine.
thanks guys.
matt9112 is offline   Reply With Quote
Old 02-25-2017, 08:59 PM   #121
zVp
zVp's Avatar
I didn't tighten the 5 side bolts, but I stopped getting this issue.
I replaced my PCV and the day after, I had that oily water, but after that, it's dry. Strange.
Also reduced my oil consumption to around... well, nothing. Used to burn around 1 quart per 8000 km, then got really bad this winter when it was 1 quart per 1000 km (). Now it's probably going to burn around half a quart per 8000 km by the looks of it, which is pretty good in my opinion.
zVp's Car Journal
Old 04-20-2017, 01:58 PM   #122
RyanMK6
Drives: 12' GTi UG Autobahn
I have this leak. I've been waiting though. I noticed some oil on my spark plugs and coil in cyl 2 and tiny bit in 3 IIRC. I have an extended warranty. But I don't wana open up a can of worms pulling shit apart. I also should probably get a carbon cleaning. I'm at around 65k and never had one done.
RyanMK6 is offline   Reply With Quote
Old 04-24-2017, 08:57 PM   #123
Logan176
Newbie
Drives: 2012 GTI
It appears as though every pic previously posted looks exactly like what I see under my hood. I have a stock 2012 with 72k miles. Timing chain tensioner and intake manifold both failed and were replaced under CPO warranty at 50k. While everything was opened up, I also had the dealership clean the valves. No noises coming from the PCV, but leaks are evident.
There may have been some oil coming from the fill cover, so I cleaned that off well. There has not been any major leakage for the past 500 miles.
I was thinking about replacing the PCV valve and the o-ring on the sensor on my own and then watching things for a bit But based on the pics below, should I just have the dealership replace the valve cover gasket since they will have to take off the PCV valve anyway?
Logan176 is offline   Reply With Quote
