zef
After getting my car aligned the left front came out -1.4, the right front -0.7. My car has tyrol collars so no wiggle room in the subframe. I'd ideally like to bring both to -1.5. I am not sure what is causing the variance, except maybe that the right front was hit in an accident (not sure how bad, was from previous owner). But the car has an entirely new front suspension (super pro LCA, B6 spindles, shocks/springs, sway bar etc)
I'd like to avoid camber plates as they're a bit harsh for DD. Superpro ball joints were recommended to me as a solid 2nd option. But after doing some research, I've read conflicting reviews about what the superpro ball joints will allow for adjustment. Does anyone have any personal experiences with these ball joints? Or should I just suck it up and run camber plates?
Secondly, my caster came out +6.6. I have the super pro LCAs, which a friend of mine has as well, and his came out +8.8. Is there a reason why the same arm on 2 similar cars would produce such a variance in caster?
