Cruised out to Southampton after a fresh wash
What's your suspension setup? That drop is perfect
Im looking to get some more turbo sounds, Should I get a turbo muffler delete or a stage 2 intake pipe?
Painted the car purple
is that actually paint or is it plastidip?
Reupholstered door insert, took way longer than I thought
Looks good. Did you drill the rivets?
I didn't actually, I had no idea what to expect going into this project so when I saw the rivets I just broke them all off with a screw driver, then when I put it back together I used my official diy super glue
Here is a pic when I did mine. I drilled the rivets then re heated the posts with a soldering iron and pushed them back flat.
Thanks, I'm running Bilstein PSS coilsWhat's your suspension setup? That drop is perfect
Everytime I buy from usp my gummy bears come as a gummy brick lol.Toys!!!!
And, this other item was also included at the USP Motorsport's box:
Toys and candies.........you can't beat that!
