Check for boost leaks?
Sparks torqued down correctly? (30nm)
Everything plugged in?
Fuel injectors?
Any engine codes?
Does the engine shake more than usual at idle? Weird idle revs?
Did you change the spark plugs, ignition coils and DV in order to fix the problem or did this problem arise after you changed these items?
Triple check the coils. It isn't out of the ordinary to get a bad coil from the retailer.
What spark plugs did you install?
