Old 03-18-2018, 07:57 PM   #841
zthang
Drives: MK6 Gti
Originally Posted by Candlemass View Post
Answering this post, and for anyone that's interested, you CAN upgrade the HU to Android 5.1.1! BUT you have to tweak it a bit and be familiar with Android ROM flashing.
Just did it and I'm more than happy with the result, as I don't have the storage limitation anymore, plus upgraded SDK.
There are 2 options, you can flash either Malaysk ROMs Lollipop 5.1.1 for any yet known MTCB-Device or the tweaked for 1GB RAM devices (like ours) MTCB/MTCC rk3188 (5.1.1) Firmware with an xposed set of MTC apps.
I flashed the 2nd to test and it is quite light and smooth (the Lite 800 x 480 openG version).
First it is recommended to update your MCU, you can use the file below provided by Eonon for my unit (MTCB-ZD-V2.83 MCU) :
Code:
https://mega.nz/#!f1I23DiC!ezJjlfQ2SgM5GnU8JzE8xygP196iuTw_vHajfuYZTEE
Also, here is V2.85 but haven't tested it yet :
Code:
http://huifei.fs-fileserver.de/content/firmware/MCUs/ZD/MTCB%20ZD%20v2.85/
After that, you can follow the procedure described in the corresponding xda threads.
Good luck
Thanks a bunch man!
zthang is offline   Reply With Quote
Old 04-14-2018, 09:34 PM   #842
MLue1
Question
Originally Posted by zthang View Post
Wrote this up awhile back, may help you
1. Under the Profiles tab, click the + sign at the bottom.
2. Choose "State"
3. Next choose "Net"
4. Then "BT Connected"
5. Click on the Magnifying Glass Icon towards the top right.
6. Choose your Eonon HeadUnit
7. Click on the Back arrow icon at the top left
8. Click "New Task +" This is the task that will execute when BT connects
9. Name your task anything ie. "TetheringOn" then click the Check Mark
10. Click on the "+" at the bottom
11. Click "Net"
12. Click "WiFi Tether"
13. Under Set, turn to "On"
14. Click on the Back arrow icon at the top left
15. Then Back arrow again and you should be back at the Profiles tab and you're done setting the WiFi tethering to turn on when the Eonon bluetooth connects.
In order to have Wifi tethering automatically turn off when the Eonon bluetooth disconnects,
1. Long press that task under the profile tab and click on "Add Exit Task"
2. Click "New Task +"
3. Name it anything ie. "Tethering Off"
4. Click the "+" sign at the bottom
5. Click "Net"
6. Click "Wifi Tether"
7. Under Set, choose "Off"
8. Click the Back arrow icon twice and you're completely done.
Is this for Android or iPhone ?
I'm hoping iPhone, as I'm tired of having to turn the WiFi Hotspot off then back on again to make it connect each time I get in the car.
Thanks
Old 04-16-2018, 06:10 PM   #843
zthang
Drives: MK6 Gti
Thanks
Sorry, this app is only available for android
