Old 04-30-2017, 10:33 PM   #15
MLue1
Rally Car Champion
Hi Flow, chances the dealer installed the UM Tune you paid for, the Canadian to US US exchange is really high.
I'm currently at my place in SC, there is a guy here with the UM 91/93 Tune and his 2.5 gurgles alot when he backs off, there is nothing wrong just unburnt fuel meeting air in an unmuffled system. You young guys get off on the sounds of open exhaust but as Guru quite accurately pointed out our normally aspirated engines require some back pressure to make power. The stock exhaust on the 2.5 was derived from the MK5 Rabbits and there are guys doing 14 second quarter mile tickets t the track, using the stock 55mm catback exhaust system and 15 inch steel wheels. That's one of the reasons I kept my stock mid muffler and only installed the GTI axle back muffler.
VW shafted us when they installed long 1st and 2nd gears in the 5 speed, that one of the reasons why the 2.5 doesn't accelerate like the GTI even with the the UM tune.
Old 05-01-2017, 06:17 PM   #16
FlowMK6
Oval Champion
FlowMK6's Avatar
Drives: Golf 2.5 5spd
I received an answer from UM, they say they only offer a stage 1 N/A or SRI version. They advise their price at 350 USD which is around 480 CAD. I paid around 700$. The dealer asked me if I wanted stage 1 or 2. But UM tells me that there is no stage 2 for the N/A. I will call Unix tomorrow and try to get the N/A version flashed.
As for our car needing back pressure, I'm pretty interested on explanations
Edit: Called UM today and they said I got the stage 1 NA tune and the back-fire sound is due to the fact that the rev hang is removed. Even if the tune is right, I would say the dealer is not honest when he told me that he put stage 2. Anyways, everything is fine. At that price, maybe I should have try out the IE tune...
Have a good day everyone
FlowMK6 is offline   Reply With Quote
Old 05-05-2017, 09:42 PM   #17
madbikes
Rally Car Champion
Drives: 2012 Golf 2.5L 5-speed
The power band is different. The final drive is also not as big on the Golf 5-speed, which is even smaller on 2012+.
APR-Carbonio intake/United Motorsports Tuned/Black Forest Industries 2.5L Lightweight Flywheel and Clutch kit/Black Forest Industries Stage 1 Motor mount+transmission mount+dogbone insert/Bilstein PSS coilovers/034 Motorsport Rear Sway Bar/StopTech ST-40 328mm Big Brake Kit/StopTech stainless steel brake lines
madbikes is offline   Reply With Quote
Old 05-18-2017, 12:35 AM   #18
MLue1
Rally Car Champion
Originally Posted by gugu1981 View Post
The UM tune greatly reduces rev-hang, which is the slow closing of the throttle plate (which controls the amount of air entering the engine) when you let up. As a result, after you have been hard on the gas pedal and suddenly let up, the throttle plate snaps shot, causing the mixture to favor fuel (rich) for a brief moment. And that unburnt fuel causes the backfire.
The UM tune actually makes the car run slightly leaner compared to stock tune. The stock tune is designed to run slightly rich to reduce engine temperature and therefore be slightly safer.
Peter, I was able to get a backup of my stock ECU a while back on my own but making sense of all the data is proving to be quite hard, I can see the maps but need to do some more studying before it makes more cents. Did I mention this will take a while. I mean there are alot of maps ! Once I figure which ones to change I'll try what you suggested.
Old 05-19-2017, 06:14 PM   #19
Yayotas
Oval Newbie
Yayotas's Avatar
Drives: Mk6 golf 2.5l
I'll film mine and see if the same that you are getting I have the UM tune and I got it at FIXXFEST from USP and I love it. I have the APR CAI and and custom exhaust.
Instagram: @Yayotas | Golf 2.5L, ST coils, One perfect Dose LED tails, DeAutoKey LED interior and License Plate, Custom Exhaust, Brada Wheels BR-10 | DUUUUUUUUVAL Go Jags!
Yayotas is offline   Reply With Quote
