Old 05-18-2017, 11:15 PM   #15
Dhruv
Drives: VW GOLF R 2010
Ok so turn the clicking noise was the fuel line touching the body on lower rpms.
Why did the new turbo smoke?
- The technician removed my Spluen catch can/PCV delete and installed the new revision of VW PCV value.
And guess what the car stopped smoking!!!!
So I asked the tech. does this mean that there was nothing wrong with my pervious turbo and he said possibly…maybe? omg!!!!!
I thought the whole point of installing catch can/PCV block off palate was to eliminate this risk.
This has been a confusing case.
Dhruv is offline   Reply With Quote
Old 05-19-2017, 07:58 AM   #16
thedude4bides
Formula 1 Driver
thedude4bides's Avatar
Drives: '12 Golf R
You aren't alone there... in the R Owners Facebook group I'm in there's several people who had white smoke when their catch can is on. Hope this mess is now behind you
thedude4bides is offline   Reply With Quote
Old 05-19-2017, 12:19 PM   #17
damagi123
FIA GT Champion
damagi123's Avatar
Drives: 2012 GTI DSG
ive seen as many people say the block off is not good for the engine as people who swear by it
sorry you went through that man
APR Stg 2, APR Intake, UR Catless Downpipe, W.A.L.K, APR 27mm Front and Rear Sways, ECS Dogbone Mount, 034 Subframe Collars, Pedalbox throttle controller, BFGoodrich G-Force Sport COMP-2, (k04 and Uni IC ready to install)
Old 05-19-2017, 12:43 PM   #18
-SnowmanMafia-
Drives: 2013 Golf R
Were you not having issues holding boost?
Custom 3in Catback | Unitronic Stage 1 | Neuspeed P-Flo Intake | Smoked Bumper Lights | OEM Euro Tails
-SnowmanMafia- is offline   Reply With Quote
Old 05-21-2017, 12:34 AM   #19
mk6'12gti
FIA GT Champion
Drives: 2012 4dr Black Gti
Yes that’s "KIWI" dollars
So, I took the car at the mechanic today and showed him the oil smoke which comes out when the can is on an angle (on a hilly slope).
He told me if the turbo oil seals are gone AGAIN it won’t be covered in warranty as it has APR tune on it.
He reckons that if that’s the case, the main cause is the tune as the new turbo should have been on the stock tune for its break in.
Funny they didn't tell me all the break in shit last time I went to pick up the car.
They are going to remove the downpipe to see if the turbo is culprit (he found it weird how it smoked only when the car is on angel.
I love my Golf very much but my pocket hates it. It has created a fear in me about EURO/modified cars now.
Never heard of a turbo needing to be broken in....
| Apr Ko4 v3.1 | Apr stage 2 Dsg | Do88 Ic | IE intake | Circuitwerks turboback | Ecs street shield | R8 coils | S3 style top | Spulen throttle pipe | BC coils | Uni dv relocate | 034 street density mounts | Hpa 75A puck | P3 Gauge |
mk6'12gti is offline   Reply With Quote
Old Yesterday, 06:49 PM   #20
Dhruv
SnowManMafia - I never encountered any boost issues - even with my old turbo it bloody pulled hard (25 psi)
Old Today, 11:09 AM   #21
damagi123
FIA GT Champion
damagi123's Avatar
i know youre in NZ but i had a misdiagnosis like that, less money, about $1000 that i got reimbursed from just making a logical argument and speaking to the manager of the dealership and being consistent and not backing down. Why not give it a go?
They didnt even give you back your perfectly working old k04
Old Today, 04:25 PM   #22
MLue1
Rally Car Champion
Hi guys, I saw this tread earlier but could just couldn't get it outa my head.
Before blaming the turbo unit there are lots of other things that can cause the failure.
The engine ECU uses the boost pressure sensor (MAP sensor.) and Intake Air Temperature (IAT) sensor to gather data about current boost conditions. The sensors allow the ECU to compare current boost pressure with boost pressure maps stored in the ECU. The Single Value Boost Limiter (SVBL) which acts like an emergency cut off for boost, all depend on these sensors as they can cause intermittent overboost conditions.
Just like a simple air leak can do major damage at the wrong time
Cheers
Tags
apr tune, failure, high boost, turbo
