Old 01-04-2017, 11:17 AM   #57
Natemk6
Drives: 2012 CSG GTI DSG
Originally Posted by Nightprowler View Post
I'm not too positive about this but can some one help me with my question. Does Cobb have race has file or not yet?
I'm not 100% sure what makes something qualify as a "race file" (maybe 100 oct?) but they have the following maps available OTS
stage 0 (stock)
valet
anti theft
stage 1 (drop in filter recommended but not required)
Stage 1+ Bigsf intake (requires Cobb Cai)
Stage 1+ stock maf (requires cai with stock MAF housing. Cobbs intake has a larger diameter maf housing)
Stage 2 ( intake and full turbo back recommended but many run with just an intake and dp)
All stage maps are available in 91 or 93 octane
Natemk6 is offline   Reply With Quote
Old 01-04-2017, 11:52 AM   #58
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
Race files are usually 100 octane maps or some kinda ethanol blend map.
mamock116 is offline   Reply With Quote
Old 01-05-2017, 09:14 AM   #59
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
What monitors should I be checking with my AP to determine if my car is running ok?
Old 01-05-2017, 06:55 PM   #60
vannoj
Drives: 2011 Tornado Red GTI 6MT
I like to watch knock in each cylinder as well as LTFT and STFT to make sure the AFR fuel trims are looking correct. I also watch AFR to make sure things are looking right there.
Tornado Red 2011 GTI 6 speed|Injen Intake|Beluga Racing Downpipe|Freektune Stage 2 Tune|034 Motorsport Dogbone Insert|Dieselgeek Sigma 6 SS|GFB DV+
vannoj is offline   Reply With Quote
Old 01-06-2017, 09:31 AM   #61
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
^ what numbers should the LTFT and STFT and AFR fuel trims normally like like?
Old 01-06-2017, 01:52 PM   #62
vannoj
LTFT and STFT should be as close to 1.00 as possible. I was having fuel trim issues with my intake on the OTS maps, so I was seeing LTFTs as high as 1.15 at times. Protune fixed that right up.
AFR should be right around 14.7 at idle. 14.7:1 is stoichiometric and will spool the turbo the most quickly, but that AFR will get richer as you apply throttle to keep temperatures under control. For the most these numbers should look okay, but I like keeping an eye on them in relation to LTFT and STFT.
Old 01-07-2017, 04:33 PM   #63
JohnoBurr
Oval Champion
JohnoBurr's Avatar
Drives: '12 GTI CSG 6MT
So I took mine in to the dealership today and they'll be doing an ECU update from a Nov. 2015 service campaign. Just curious if when I flash my stage 2 again after the update if it will incorporate the changes or if it will have been literally worthless having them update it. Does the update change the engine box code? Also, I didn't uninstall the Accessport before taking it in, hopefully that won't cause any problems when flashing it back to stage 2.
Cobb Stage 2 | RSR Clutch | Eurojet TBE | ARM FMIC/TOP | I.E. Intake | DV+ | 034 Street Mounts | Vibratechnics Dogbone | Fluidampr | Tyrolsport Deadset | H&R 24mm RSB | Neuspeed RSe12's | VWR Springs
JohnoBurr is offline   Reply With Quote
Old 01-11-2017, 04:15 PM   #64
jon570
Drives:
I saw some other mentioned it months back but is there anything still in the works for being able to use launch control? or 2-step?
jon570 is offline   Reply With Quote
Tags
accessport, accesstuner, cobb, cobb tuning, tune
