Old 12-28-2012, 06:24 PM   #15
Ina12K04GTI
Drives: 2012 GTI, APR K04/ supporting mod
Originally Posted by Wastegate13 View Post
Smiley do you drive a united grey 2 door?
I drive a united gray two door in Coral Springs
Ina12K04GTI is offline   Reply With Quote
Old 12-28-2012, 08:18 PM   #16
Modshack
Formula 3000 Champion
Modshack's Avatar
Drives: '13 Beetle TDi Conv., '14 C7 Chebby
Originally Posted by XZT123 View Post
Approximate boost PSI
Stock - 8 PSI
Stage1 - 15 PSI
K04 Turbo - 20 PSI
I'm at 12 PSI (stock) with my Boost Machine, but that's about as far as you can push it un-tuned..
Modshack is offline   Reply With Quote
Old 12-28-2012, 08:20 PM   #17
Djmikeyd
Formula 3000 Driver
Djmikeyd's Avatar
Drives: 2011 Black Autobahn 4Dr
Stock - 8 PSI
Stage1 - 15 PSI
K04 Turbo - 20 PSI
For me stage 1 = 23 psi
For the NY/LI Euro enthusiasts.
Strictly Euro Group on Facebook
Revo Stage 2 , SPM Street TBE, Forge Twintake
Djmikeyd is offline   Reply With Quote
Old 12-28-2012, 08:37 PM   #18
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
im ko4 and i peak at 23ish
Originally Posted by GOBbluth View Post
I cut the tether off. When I get to the pump, I remove the cap and chuck it into the nearest bush, patch of trees, or some sort of wet lands. I pump gas. Then I spend anywhere from 5 to 165 minutes retrieving the cap. I screw it back on and drive away. I'm not letting it dangle against the paint and I don't know any better way.
GTI_likeurmom is offline   Reply With Quote
Old 12-28-2012, 08:41 PM   #19
gfox33
gfox33's Avatar
Drives: 2011 GTI
About 19 for me with stage 1.
Sold: Deep Black 4 Door DSG - APR Stage 1 - OZ Alleggeritas - 30% Tint - Magnaflow CB - OEM LED Tails
Now: 07 Toyota 4Runner SR5 4x4 V6
gfox33 is offline   Reply With Quote
Old 12-28-2012, 09:04 PM   #20
XGC75
Formula 1 Driver
XGC75's Avatar
Drives: into shit
I get 12.5 stock (via VCDS, peak) and I hear stage 1 is 18. What gives with all these different read outs?
butchered by autocorrect
XGC75 is offline   Reply With Quote
Old 12-28-2012, 09:05 PM   #21
Djmikeyd
Formula 3000 Driver
Djmikeyd's Avatar
Depends on gauge, tune etc
Old 12-28-2012, 09:15 PM   #22
MBorVW
Formula 2 Driver
MBorVW's Avatar
Drives: 2015 VW GTI 4dr SE DSG
What is that?!!
Also: 2012 Tiguan LE 2wd
MBorVW is offline   Reply With Quote
Old 12-28-2012, 10:45 PM   #23
Modshack
Modshack's Avatar
Originally Posted by MBorVW View Post
What is that?!!
It's a "Boost Machine".....Made about 500 of them over the years, but don't anymore. It's an interesting concept and was wildly successful on the 1.8T.. Read more here:
http://www.modshack.info/BM.htm
Old 12-28-2012, 10:49 PM   #24
littleazn248
Formula 3000 Driver
littleazn248's Avatar
Drives: Audi SQ5/ F30 335i
So is this a replacement for the DV so you can dial how much boost to hold before vent?
Formula 1 Pinnacle F:50% R:15% / Smoked Side Markers/Modded Torque Insert/ Depo R LED Tails/ Neuspeed Springs/ Koni Strt/ aFe Pro-Dry S drop in
littleazn248 is offline   Reply With Quote
Old 12-28-2012, 10:54 PM   #25
Modshack
Modshack's Avatar
Uh...No. The DV doesn't have anything to do with making boost. This adjusts the air signal to the Wastgate actuator . Read more at the link.
Old 12-28-2012, 10:59 PM   #26
littleazn248
Formula 3000 Driver
I'm always thinking the DV is there to hold boost. After some googling I see the true purpose.
Old 12-29-2012, 01:45 AM   #27
chrisisnapping
chrisisnapping's Avatar
Drives: Bye: GTI DSG Hello: Mustang GT 6MT
have you tried this on a tuned car yet?
then again I think there isn't too much room left in the IHI turbo after stage 1/2 anyways.
Old: APR Stage 2, UR Metal Cat/Resonator down pipe, Modshack Intake, BSH TB Pipe, Coolingmist DPI Meth
New: Stock for now.
chrisisnapping is offline   Reply With Quote
Old 12-30-2012, 10:12 PM   #28
Keizerjohn
Keizerjohn's Avatar
Drives: 2012 GTI CSG 4DR MAN
Stage 1 risk
Smiley, besides the dreaded "modbug", be aware that the 30% increase in torque from an APR Stage-1 tune will probably cause clutch-slip if you drive a 6M. I have a 2012 only 5 months old and got the tune 2 weeks ago. Unfortunately the stock clutch just can't seem to handle the extra torque in gears 4-6.
Life is short. Make the most out of every minute!
'06 MX-5 Miata set up for STR-Class Auto-X, '12 GTI APR Stg-1, 6-Spd Man
Keizerjohn is offline   Reply With Quote
