#1 |
![]() Drives: MKVI GTI Join Date: Apr 2011
After 50K, if I were to re-do mods again...
I just hit 50,000 miles yesterday and it got me thinking — if I could go back in time and redo all my mods, which one would I do first?
1. Tires - get whatever max summer tires you can afford but man oh man the Michelin Pilot SuperSports are godly. 2. XDS setting 2 - this blew me away and I can't imagine going back to stock. It really helps the car rotate in and it's a simple 2 minute mod if you have VCDS. 3. APR stage 1 with APR/Carbonio intake - APR AU already proved that the intake is the best on the market netting +17HP and the carbon fiber helps with shielding heat from the engine bay. 4. front and rear sway bars - faster turn-in, increased agility, more predictable understeer, heavier steering. I cannot stress this enough - GET BOTH BARS. For reference I have H&R 24mm front (medium), 26mm rear (stiffest). 5. Whiteline Anti-Lift Kit - makes the car track much more straighter and keeps the wheel pinned to the pavement for better traction in all but extreme launch situations. 4. Unibrace XB - stiffer chassis makes for better chassis. 5. Unibrace UB - increases stability in braking by creating less dive (and lift during accel.) 6. APR stage 2 with downpipe and cat-back - at this point more power can be more fully appreciated. I wish I can put a mechanical LSD on this list and it may deserve the #1 spot, but I haven't had the fortune of driving a GTI with it and spending $2500 at this stage on the car is not as practical as before. Also, I feel certain mods may not offer the benefits they claim. Changes in a car's feel/behavior may not necessarily equate to positive changes. Things like mounts and bushings just make the car rattle (especially with the A/C on) and uncomfortable. Try those polyurethane products at your own discretion. |
#2 |
![]() Drives: 2010 CS GTI Join Date: Nov 2009
Thanks for this, it's really helpful for someone that is starting out.
I'm thinking of swapping the all seasons for summers next year...the all seasons are really holding this car back in the handling department! |
#3 | |
![]() Drives: 2012 Carbon Steel Grey Autobahn GTI Join Date: Jun 2012
Yea same here!! Want to burn them through as fast as I can!! ![]()
GIAC Stage1 (Stage 2 Pending)! BSH Air Intake! Yellow Tint Fog Light! CST TBE (Pending), P3 Gauge (Pending) |
#4 |
![]() Drives: 2014 Ram 1500 Hemi/2007 Audi A4 6MT Join Date: Apr 2012
I always thought of changing the XDS setting but never thought it would make much of a difference...
2010 GTI SOLD AWE K04 | APR tuned | AWE DV relocation kit | APR R1 DV | CTS Turbo intake | USP 3" DP | 3" CTSTURBO Exhaust | NewsouthPerformance Boost gauge | CM FX300 Clutch kit | Ed's LED tails | 18" VMR 710's | Bridgestone Potenza RE760 sports | OEM front lip | H&R sport springs | 35% tint | VCDS HEX+CAN |
#5 |
![]() Drives: 2013 GTI Join Date: Dec 2012
I agree with the XDS, made a huge difference. I also changed the brake setting and like it too.
Did you change springs? Can you elaborate a little more in the whiteline kit?
2013 GTI, APR stg 1 and Carbonio |
#6 | |
![]() Drives: 2012 GTI Join Date: Nov 2011
However, once you get sways, shocks, and springs the XDS just gets in the way of taking the car to the limit. I went back to XDS default after I upgraded the suspension, now I can blast up and down on and off ramps at ridiculous speeds. ![]()
Stage 3 soft touch plastics | Should I get an EVO X MR? |
#7 |
![]() Drives: 11' GTi. CSG, 6MT, Autobahn Join Date: Feb 2011
Intersting. This is almost exactly what I had planned for my car.
CSG GTi Lexus GS430 |
#8 |
![]() Drives: 2011 gti cw mt Join Date: Jul 2011
That's great feedback. Maybe install an LSD when the clutch goes?
#9 | |
![]() Drives: 2010 GTI 2dr red Join Date: Apr 2010
An overall very good start!
2010 RED GTI, 2-doors, MT, APR Stage2 v1.2, B&B Turboback, S3 Intercooler, Carbonio intake Stage1&2, STD Coilovers R1, H&R R-swaybar, BSH full mounts kit, Whiteline bushings, Forge short shifter kit, Front-Brakes stage3, Unibrace UB, XB, Michelin PSS, O.Z. Black Ultraleggera ESP OFF! |
#10 |
![]() Drives: 2012 GTI, APR K04/ supporting mod Join Date: Jul 2012
I don't mean to knock everything you have said here as I'm sure some will find it useful. However, a Wavetrec LSD is a $1000, with the numbers you have put out, that would leave $1500 for labor. I've had a chance to see one installed & it's not that much more difficult than doing a clutch. Also, there have been many dyno charts with & without a Intake, most showing no real gains. 17 HP is seriously overstated.
#11 | |
#12 | |
Regarding the intake HP, I have to just trust some of the dyno charts because I'm not going to spend the money to compare and dyno all the popular MK6 intakes on the market. But I stand strongly by my belief that APR makes the best intake for our cars. |
#13 |
![]() Drives: 2012 GTI Join Date: Feb 2011
I have the whiteline anti lift kit and can't really say it's a worth while mod. It may just be the fact that i'm k04 and it's not really going to matter waht I do from a tire/suspension mod because of the torque. I installed the k04 first, drove around for about 5k miles and then had the WALK put in, and really didn't notice a difference. the k04 may just be above the limits to make a difference and with stage 1 or stage 2 as you are reviewing, it may be worth it. But for k04 guys or if you plan on going k04, It's an expensive mod for little return, imho
APR K04---APR Carbonio Stg 1 & Stg 2---APR Intercooler---AWE Turbo Outlet Pipe---OEM S3 Short Shifter---UR Catted-Resonated Downpipe---BFI Torque Arm Insert---H&R Sports Springs---Whiteline Anti-Lift Kit---Whiteline rear bushing kit---SB Stage 3 Disc Only---USP SS Brake Lines---Hawk HPS pads |
#14 | |
What I noticed with the WALK is the steering feels much heavier and weightier. My friend owns a 2012 X3 and she said my car feels very "big" and reassuring because it tracks so straight and corners much more confidently because the tires are more planted and the contact patch isn't shifting as much during steering changes. Big car stability with small car nimbleness. |
Display Modes | |
