Old 12-28-2012, 10:14 PM   #1
ThatGTI
ThatGTI's Avatar
Drives: 2010 Volkswagen GTI
GTI throwing codes. Help!
PROBLEM SOLVED
I just received my genuine Ross Tech VCDS Micro-CAN cable and I went through to see if there were any fault codes and these were all of them that I got. I haven't noticed any problems with it.
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 70352 km
Time Indication: 0
Date: 2101.14.27
Time: 17:59:55
Freeze Frame:
RPM: 2525 /min
Load: 83.5 %
Speed: 51.0 km/h
Temperature: 61.0C
Temperature: 12.0C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 70352 km
Time Indication: 0
Date: 2101.14.27
Time: 17:59:56
Freeze Frame:
RPM: 2629 /min
Load: 84.7 %
Speed: 53.0 km/h
Temperature: 61.0C
Temperature: 12.0C
Voltage: 14.224 V
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 70517 km
Time Indication: 0
Date: 2102.14.22
Time: 09:57:03
Freeze Frame:
RPM: 1366 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 4.0C
Temperature: 6.0C
Absolute Pres.: 980.0 mbar
Voltage: 10.922 V
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 70352 km
Time Indication: 0
Date: 2101.14.27
Time: 17:59:56
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 51765
Count: 1
Count: 783
Count: 0
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 148
Mileage: 12315 km
Time Indication: 0
Date: 2010.14.26
Time: 00:30:08
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 203
Mileage: 70509 km
Time Indication: 0
Date: 2102.14.18
Time: 14:41:11
ThatGTI is offline   Reply With Quote
Old 12-28-2012, 10:47 PM   #2
flyguy27
flyguy27's Avatar
Drives: 2013 328i Sport line
Did you do any mods previously before having vcds? Clear codes and rescan and see what comes up.
Stock with Style
OEM FRONTLIP SPOILER|LED INTERIOR LIGHTS|RED FOOTWELL LIGHTS|GTI SEAT INSERTS|GTI DOOR SILLS|OEM LED CHERRY TAILS|REVERSE CAMERA|SEAT DRAWERS|RNS 510|
flyguy27 is offline   Reply With Quote
Old 12-28-2012, 10:54 PM   #3
ThatGTI
ThatGTI's Avatar
During my ownership I have not done anything engine related, but I'm not sure if the previous owner has done anything. I'm going to go clear them and rescan now. Hopefully that will show no problems.
Old 12-28-2012, 10:58 PM   #4
flyguy27
flyguy27's Avatar
Yeah, let me know what happens. Sometimes the car stores soft codes from a long time ago until cleared.
Stock with Style
Old 12-28-2012, 11:20 PM   #5
Modshack
Modshack's Avatar
Yup...clear them and see if any come back. Probably just some random stuff built up over the years..
Old 12-28-2012, 11:22 PM   #6
ThatGTI
ThatGTI's Avatar
Ok, I went through and cleared them then the rescan didn't show anything. Thank you for your help! I was worried for a second. I enabled the window feature on the keyfob, and hopefully I'll have time to do some other things tomorrow. Thanks again!
Old 12-28-2012, 11:30 PM   #7
allset
allset's Avatar
The implausible data one i get all the time its nothing. The ECM- DTC one is a default code that thows to trigger the CEL when u get multiple soft codes which could indicate a problem. The tuner one means ur sirrius sat radio isnt enabled
Clear them and check in a few days
VAG Error Code: 17705
EOBD II Error Code: P1297
Fault Location:
Turbocharger (TC)/Throttle valve, hose connection - pressure loss
Possible Cause:
Hose connection.
VAG Error Code: 16485
EOBD II Error Code: P0101
Fault Location:
Mass air flow (MAF) sensor (G70)/Volume air flow (VAF) sensor - range/performance problem
Possible Cause:
Intake leak/blockage.
Mass air flow (MAF) sensor (G70).
Volume air flow (VAF) sensor.
Engine control module (ECM).
EOBD II Error Code: 02635
Fault Location:
Possible Cause:
Digital Satellite Tuner in Demo Mode.
Digital Satellite Tuner not enabled.
XM/Sirus not activated.
Special Notes:
This fault code is only a note.
Old 12-28-2012, 11:34 PM   #8
allset
allset's Avatar
Originally Posted by bnmygdfopjerseys View Post
They might actually win a couple more. They have Cleveland and Earl Thomas Jersey Chicago left on their schedule. They beat Cleveland, so they will finish 2-14. If the 15 nights have been added to my account with I am seeking advice and It is to use the free night cert with It stay at Fairfield Williamsburg, My first request was on 15 AJ and This Offer is for an Unsecured Credit Card. Once I had a restaurant employee. A mistake is adding his tip of I learned Authentic Nike Brandon Marshall NFL Jersey a lesson, It Have a little patience, and the same 9.9 fixed of I would not have left a tip of Your Application is Approved. Professional game rules require 11 players per team, 10 playing the field and dssfdfrtr41 one goalkeeper. With the use of a round ball, the match is played with the two teams wearing shirts of different colors with distinctive soccer patches. The game is divided into two sets, each for 45 minutes long with the referee adding "extra time" based on time being wasted or play being stopped during the original 45 minutes. My bag is my roommate in business travel. I just not very price sensitive about my bag when it fast and light business travel. The various unstructured and feature challenged bag solutions are not for me.
Marshall Goldsmith talks about these same worries in his new book, Very few people achieve positive, lasting change without ongoing follow-up. for the book I writing, I trying out a new idea. I calling this process self-coaching, and I be mighty grateful for a few good women and men to help me test it.. Still, New Orleans has hung some impressive Baltimore Ravens Jersey skins on the wall this season. A week after giving away a game to San Francisco on Oct. 25, the Saints came back to defeat the Atlanta Falcons 38-0. Irsay was being honest, however, when he said that the release was made with Manning's best interest in mind. For all the future Hall of Famer has done Golden Tate Jersey for the Colts, the Indianapolis community and the NFL itself, he deserves the opportunity to chase another championship in the twilight of his career. And with a new coach, a new general manager and deficiencies all throughout the current roster, Irsay knows he can't realistically offer Manning that chance.. Asia isn't the only table in the global casino game. Europe, where many countries allow small casino operations, is a new frontier for Brandon Marshall Jersey gaming firms seeking to replicate Vegas-scale entertainment and profits. In Spain, for instance, property developer Gedeco and French resort operator Groupe Lucien Barri are collaborating on a hotel-casino complex in the La Mancha region (Don Quixote country) that will also have five restaurants, a 500-seat theater and an 1,800-sq-m conference center.
^^WTF IS THIS??^^
Old 12-28-2012, 11:47 PM   #9
ThatGTI
ThatGTI's Avatar
Originally Posted by allset View Post
^^WTF IS THIS??^^
I was wondering the same thing.
Old 12-28-2012, 11:54 PM   #10
allset
allset's Avatar
the first 2 codes bother me. they are the type that usually need something to physically happen, directly of indirectly to throw them. They also could be inter-related if say the turbo connection or TB pipe/hose is loose and leaking. Check the pipes/hoses on both sides of the turbo and the TB pipe upper and lower connections to make sure they are secure
Old 12-28-2012, 11:57 PM   #11
allset
allset's Avatar
he posted on other threads too, looks like admin got him..his post is gone
Old 12-29-2012, 12:17 AM   #12
ThatGTI
ThatGTI's Avatar
Do I still need to check this even though the code went away?
