Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Technical Topics > Tracking / Autocrossing / Driving Techniques
Old 01-28-2017, 01:38 PM   #1
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
Steering ratios and Spindles ( stock - passat - TTRS)
I am not responsible for any mods you do to your car. Please be safe. This is written for your minds entertainment, nothing more.
So I wanted to share some of my experiences and bring up for discussion something that has been near and dear to my GTI Experience.
My car sees the track fairly regularly for the last 6 years. and has a personal best of. 1:37.85 at Canadian Tire Motorsports Park( Mosport) GP (passat spindles)
I have tried all above spindles on my car. Currently running safely the TTRS setup( have not tracked it yet)
My car is a 2010 which has the 15.6:1 steering ratio. 2011(some may be split) and on have the 16.4:1 ( slower ratio). So my experiences will vary with what rack you have.
One of the biggest complaints on the TTRS( and all TT) is that their rack is a 16.9:1 (even slower). So in theory a TT spindle with a 2010 Gti rack is the sportiest setup.
Now to the spindles.
My stock ones looked like garbage after 2-3 canadian winters, hence my quest for an aluminum spindle began.
The Passat Spindles were the obvious choice. I also got a boxter caliper setup which worked fine with the passat spindles due to mounting.
One of the tings about this setup is the shorter arm of the spindle which leads to quicker steering. And boy is it quick. So quick that i could get my stability light going just from switching lanes... Yes everything bolted on to spec. Very very quick, maybe too quick sometimes. Nothing that I could not handle, but definitely requiring your concentration. I guess the 2012-2014 Gti will have slightly less quick steering, because of the slower rack which might lower the frequency of intervention of the nannies.
Additionally, as I got quicker, I went for 18z Cayenne Setup matched with the TTRS master cylinder.
Guess what though, this doesn't work with the Passat Spindle, because of the large ears on the Passat spindles throws everything out of whack.
So I had to go back to stock spindles..... to run the 18z while working on fitting the Audi TT spindles
I knew if I would be able to switch to the TT setup, I would be able to have my brakes and my aluminum Spindle.
To fit Audi TT spindles was tricky, and people have done it before , but none were really plug and play.
Hurdles:
- increased track width aka fender issues.
- audi TT inner-outer tierods don't screw in safely in the Gti steering rack. People have milled down the rack... risky stuff but admirable.
- Mistery Inner tierods sold at high price...
- even with those the inners Gti tie rods are too tiny in diameter and overall profile to securely be bolted on the spindle.
-thebruce mentionned he has friends that have swapped the whole rack for a TT, but the TT ratio is 16.9:1 , hence not very sporty.
Advantages:
-aluminium spindle
-increase center roll
-increase track width
-ability to fit more tire/wider wheels
-ability to run Porsche brakes 18z
-increased cooling from running the Audi TTRS, because of the lower ball joint attachment, the duct actually runs lower to the ground and collects more air.
The final solution involved sacrificing the Passat Spindles.
Yes the outer tierod bushing from the Passat Spindle is pressed out, and switched over to the Audi TT spindle.
Before this I even went to get a Audi Q7 outer tie rod, but alas it was to big, so not enough hold to be secure.
My goal with the GTI has basically been to emulate on a smaller scale the Audi TT VLN FWD which set new benchmarks for what a FWD car could do.
Matching the Audi TT spindles with the 15.6:1 ratio, ends up being probably the sportiest, highest performance combo for our platform.
This should also contribute to lowering the nannies intervention that was somewhat annoying with the Passat spindles combination. More testing needs to be done.
I am now one step closer.
More updates as the new driving season is around the corner.
carsfeverguy is offline   Reply With Quote
Old 01-29-2017, 01:54 AM   #2
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
Placeholder for more impressions.
Old 01-30-2017, 03:17 PM   #3
APRMK6GTi
Formula 5000 Champion
APRMK6GTi's Avatar
Drives: 2012 GTI
subbed, still need to install my passat spindles!
2012 CSG GTI 6SPD | APR Tuned | AWE K04 | APR Carbonio | IE FDS IC | 42DD DP | Magnaflow CBE | Neuspeed TOP/ACP | GFB DV+ | DG S6 | OEM MSB | Verdict SBB | HST RSR | ECS Bleeder Block | SuperPro LCA/ALK | 034 TAI | AST | OZ | TT-RS Brakes | Whiteline 24MM F&R | Tyrolsport | Unibrace XB/UB/RB | EuroSport LB | Euro OEM LED | OEM Aero Parts | P3 |
Nor Cal VW Drivers Club Feel free to join!
Old 02-20-2017, 03:21 PM   #4
darkGTI
Oval Newbie
Drives: VW GTI MK6
Sub'd, very good info here.
APR Stage 2|Unitronic Custom Intake|R8 Redtops|HPA SS|SPULEN Coilovers|SPM 3'' CBE|AWE Downpipe |034Motosports CatchCan|Unibrace XB|Unibrace UB|GFB DV+|Neuspeed TOP|BSH TBP|Godspeed IC|HSTuning RSR clutch|Wavetrac LSD |Fluidampr Crank Pulley|Polar FIS|PTP Turbo Blanket|H&R Sway Bar 26mm front sway bar|034Motosports 25.4mm rear sway bar|TyrolSport Front and Rear Deadset|TyrolSport caliper stiffening kit|KMDTuning SS Brake lines
darkGTI is offline   Reply With Quote
Old 02-23-2017, 09:51 AM   #5
kern417
Formula 2 Driver
Drives: '09 Jetta
my tt steering rack should be here friday. i'll play with it this weekend and post pics of what i find.
also some of your pictures aren't showing for me (everything before the tie rod comparison), but it may just be my computer.
do a burnout.
kern417 is offline   Reply With Quote
Old 02-23-2017, 11:29 AM   #6
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
I didn't post other pictures.
Good grab on the steering rack. Really your only other choice, to what I did.
The ratio is rated at 16.9:1, so slower than the GTI, but only experience will tell us.
Old 02-23-2017, 11:50 AM   #7
jay745
Mod Flanders
jay745's Avatar
good info
Old 02-23-2017, 03:45 PM   #8
onefastGTI
Touring Car Newbie
Drives: 2013 GTI
Mystery inner tie rod = MK4 R32 inner tie rod
onefastGTI is offline   Reply With Quote
Old 02-24-2017, 09:50 AM   #9
kern417
Formula 2 Driver
Drives: '09 Jetta
ah gotcha. i just want to see what combos work. i have an '09 mk5 so i'm *assuming* it's the same as pre-2011 mk6, but who knows. in the end if it's that bad i can swap back. i just want to see if the ends mate up and can get good pics of the differences side by side.
cool, but i'm still not convinced that it's a fix. you need the ttrs outer no matter what, unless you do the bushing swap.
do a burnout.
Old 02-24-2017, 11:57 AM   #10
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
Yep you need both , unless you get the rack.
Old 02-25-2017, 06:16 AM   #11
onefastGTI
Touring Car Newbie
Drives: 2013 GTI
yeah, I'm just putting it out there so people don't go spend $300 for something you can get for $50 easily.
Old 02-25-2017, 11:45 PM   #12
kern417
Formula 2 Driver
Drives: '09 Jetta
oh yeah it's def good info. i haven't seen it actually posted anywhere, just the pictures.
do a burnout.
