Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > CANADA
Old 03-03-2017, 06:22 PM   #29
Kato
Kato's Avatar
Drives: 2012 CW DSG GTI
Independent Tuning?
APR ECU Stage 2+/TCU Stage I
Bilstein/WhiteLine/034/TyrolSport/Stoptech/Brembo/Neuspeed/GFB/Newsouth
Kato is offline   Reply With Quote
Old 03-03-2017, 06:52 PM   #30
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Originally Posted by Kato View Post
Independent Tuning?
Yup, lol.
I got the tensioner replaced to prevent this... and it happens right when I replace it LOL
I think there wasn't enough oil pressure when I was cranking up (not too sure?) and it skipped a tooth... I'll probably call back to see if they can inspect other things too.
They were nice about it - they double checked and will re-do the timing chain on Tuesday.
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 03-03-2017, 07:00 PM   #31
Kato
Kato's Avatar
Originally Posted by zVp View Post
Yup, lol.
LOL damn...well, I guess if it ain't broke, don't fix it!
Old 03-07-2017, 05:34 PM   #32
zVp
zVp's Avatar
Got the car back and it needed a new chain and chain guide. Car runs a little smoother and sounds a little quieter (minus the loud fuel injectors).
Great guys at IT as always!
zVp's Car Journal
Old 04-23-2017, 08:31 AM   #33
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
I've done my carbon cleaning recently as 63k at k&h. Car definitely runs hella smooth now and is more peppy. My valves were pretty nasty. Maybe due to the short drives I have to take for work.
Although a random rough idle I get is back. Not sure what that is. It's not misfiring.
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 04-23-2017, 10:47 AM   #34
zVp
zVp's Avatar
On start-up and it will shake a tiny bit before RPMs drop?
zVp's Car Journal
Old 04-23-2017, 11:47 AM   #35
nik
nik's Avatar
Yeah! Exactly! It even does it for a while afterwards when I leave the go station but that's just b cause I want to get out of dodge fast. Any idea what causes that?
Old 04-23-2017, 03:34 PM   #36
MLue1
Lightbulb
Did you clean your throttle body? If it's gummed up it will cause a rough idle at start up, just remove the pipe going to the TB and spray with carb cleaner and use a rag to clean the barrel, the sides and back of the butterfly.
Old 04-23-2017, 07:27 PM   #37
zVp
zVp's Avatar
I've looked for answers to this and... apparently it's normal
zVp's Car Journal
Old 04-23-2017, 07:42 PM   #38
nik
nik's Avatar
Hmm I'll give that a go. I guess that wasn't part of the carbon clean process. I have TB cleaner at home too. Will update when I do it next weekend hopefully
Old 07-09-2017, 08:53 AM   #39
nik
nik's Avatar
I never ended up cleaning the throttle since life got in the way to work on the car. But ended up swapping my stock coils for red top ones. This seems to have addressed the issues. I guess they were on there way out after 67k. I guess they had some internal degradation so at certain temps they would act up. Had the same issue with my old car where the spark plug boot would arc when it was slightly damp outside
