Old 09-30-2013, 06:23 AM   #43
Hurdy
Drives: Steel Grey Golf .:R DSG
Recent dyno run on pump gas plus WMI.
My result below.
Over 350bhp by 4800rpm and flat lines over 390bhp between 6000-7000rpm
Also over 300lbft of torque available from 3200-6600rpm, with over 350lbft from 3500-5500rpm.
The most noticeable thing is absolutely no dips in power delivery, just one big surge of power to 7000rpm.
The bhp was measured from the rundown drive losses in fwd mode.
Direct measure peak was 346whp.
GOLF R
Hurdy is offline   Reply With Quote
Old 11-15-2013, 12:27 PM   #44
Hurdy
Well, soon got a little bored of the L0400 and so I am upgrading to an L04XX. Big step as it gives 100+ bhp over my current set-up!
Also took the car out for some snaps as it has just had its winter wax protection done.
Last three are my favourites.
Particularly the last one. arty B&W.
GOLF R
Old 11-22-2013, 01:41 AM   #45
fast2ghl
fast2ghl's Avatar
Drives: 2012 GTI MK6 3-Door DSG FBO k04-64
wow impressive numbers man awesome!
2012 MK6 GTI DSG / 3 Door - Tornado Red
MODS: Unitronic - CTS K04 - FullyBolted / Neuspeed / 42DD / APR Carbonio / HPA / UNIBRACE / 034 Motorsport / KSport / CCW / Podi / OSIR / Hella ||| BUILD THREAD
fast2ghl is offline   Reply With Quote
Old 11-24-2013, 02:24 PM   #46
Hurdy
Update........
So with a little more tweakage, setting and playing with the boost controller I decided to have a dyno run on a hub dyno to get some accurate hub/wheel HP. The dyno was a Dynapack, which is the same make/model that APR use to run their Golf R's on in the USA. The figures are at the hub, so basically whp!!!
Even a minimum 10% addition to these figures for drivetrain losses works out at 408+bhp, more realistically would be around 12-15% losses. The run was only done with 99ron and 50/50 water, methanol. The run also only went to 6200rpms and was still gaining power. When Rick tried to alter the dyno to use more rpm's the dyno didn't want to know, so there are a few more whp in the bag yet. For comparison APR stage 3 figures are shown under my graph and are 371whp and 394wlbft compared to my 371whp and 388wlbft.
GOLF R
Old 11-24-2013, 05:15 PM   #47
GreasyGinzo
GreasyGinzo's Avatar
just to be clear you are running the LO400 which used to be the LO380 not the bigger LO4xx right?
Build Thread / Life Story
Old 11-24-2013, 08:04 PM   #48
Hurdy
Correct. Plus WMI and on an electronic boost controller running 2 bar boost.
GOLF R
Old 11-24-2013, 08:31 PM   #49
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
what turbo is this??
Old 11-24-2013, 10:14 PM   #50
Hurdy
It is the L0400.
GOLF R
Old 11-24-2013, 10:15 PM   #51
GTI_likeurmom
GolfMK6 Elite
Drives: Veyron 16.4
Originally Posted by Hurdy View Post
It is the L0400.
oh ok, im not familiar with big turbos. good luck man.
Old 11-25-2013, 03:31 PM   #52
Hurdy
The sales pitch off Loba's website.
We are proud to present the ultimate and the original OEM+ Sport Turbocharger Upgrade for 2.0 TFSI engines. The LO400 turbocharger is the result of many years of development and evolution on the 2.0 TFSI platform. Evolved from the respected LO380 Turbocharger.
In order to produce a LO400 we utilize a brand new factory BorgWarner KO4 turbocharger and optimize with 5-Axis CNC machine, modifying the compressor housing and inner surface for optimum flow, then 5-axis CNC modify the turbine housing to reduce exhaust gas back pressure and maximize throughput to increase output.
At the heart of our LO400 is the latest state of the art, bigger more efficient V3 LOBA Motorsport LO-2580 forged billet compressor, that is unique in design, geometry and size, but is extremely light in weight at only 39.8 Gram, yet still very strong. LOBA Motorsport forged billet compressor wheels are 25% lighter than some original used cast items and lighter than standard billet types, but still has greater strength and durability over a cast compressor or standard billet types. Being a forged billet the nose and stem of the compressor wheel can be CNC machined significantly smaller to allow for a greater blade area and diameter for inducer size, blades can also be made thinner, so more efficient and flowing more air then say same size billet compressor wheel. The end result is a compressor of extreme lightness, fast unmatched response and superior efficiency.
We also lighten and clip the BorgWarner turbine for increased flow and CNC machine the exhaust turbine housing to reduce exhaust backpressure and increase output.
We precision balance the turbine wheel/shaft and compressor wheel to far beyond oem tolerance as single parts, first to less than 0,05gmm then together. Last but not least is we modify the actuator and use a reinforced LOBA bearing for durability.
The end result can be less lag and better response than even a stock KO4, yet still flowing much more air mass so making and holding more power to the redline. The LO400 turbocharger is a great compromise between power output, turbo response and longevity. A OEM+ turbocharger upgrade well suited for motorsport use or street.
The following LOBA specific optimizations were applied
NEW V3 LOBA LO-2580 “Extended Tip” state-of-the-art forged billet compressor wheel
LOBA 5-axis CNC machined re-profiled compressor housing and backplate
LOBA clipped turbine wheel
LOBA Optimized clearances
LOBA Modified actuator
LOBA Uprated bearing
LOBA Superior Balancing
GOLF R
Old 11-25-2013, 08:03 PM   #53
Bozz
Bozz's Avatar
Interesting how your torque figures peak sooner...i.e. 3500-3600 rpm vs. 3900 rpm
They are using a Garrett GTX28?? turbo, whereas your is the Loba 400...interesting stuff.
Also, and totally off-topic, but what is your front fender-to-ground on your car, if you know it offhand?
Old 11-26-2013, 08:16 AM   #54
Hurdy
I'll get the fender measurement for you later today.
Yes the Loba does spool quicker. Below is an overlay graph of APR stage 3 on 93 octane V Loba on 93 octane +WMI. Both are WHP and both done on a Dynapack hub dyno. As you can see, lower down the rev range I have as much as 20+whp and 50+wlbft more than the APR R.
GOLF R
Old 12-01-2013, 08:40 AM   #55
Hurdy
Fender to floor is 11cm
GOLF R
Old 12-02-2013, 01:46 AM   #56
Bozz
Bozz's Avatar
Thank you for measuring. Alas, there is no way I could run 11 cm (4.3 inches)...I'd scuff on my driveway. Great look though. And great pics of your car in the countryside.
