Old 03-09-2018, 06:15 PM   #1
Noodle
Noodle's Avatar
Drives: 2013 Gti Wolfsburg, 6-Speed, White
Weird rev drop (Video)
Cant really explain this but its weird, watch the video
https://www.youtube.com/watch?v=IKoYn3jehmA
I got a weird p0145 code like 2 months ago, cleared it and didnt come back till now. after I filmed this video I got a p0145 and p2196 code.
So the next day after I drove the car (still dealing with the rev drop as seen in the video) and scanned it with my acessport and the p2196 is gone
To make a long story short, I now am dealing with the rev drop problem, I have a p0145 check engine light and I might have an exhaust leak. Can the leak be causing this problem or is it something else? thanks in advance.
'13 Gti Mk6 Wolfsburg Edition - 6 Speed -Stratified stage 2 - Resonator Delete - Led Tails - Apr Carbonio Intake - Short Shifter + Bushings - Arm Motorsports Catted Downpipe - Dv+- Other stuff
I got the Golden Noodle
Noodle is offline   Reply With Quote
Old 03-09-2018, 06:18 PM   #2
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
That's what a vacuum leak looks like. Had a similar issue when my intake manifold was leaking. I think a bad pcv can represent similar symptoms too. It could be something simple like a leak in a boost gauge hose.
Old 03-09-2018, 07:05 PM   #3
Noodle
Noodle's Avatar
Don't think it's the pcv, i pulled the oil cap and it started to idle rough so I think the pcv is fine, I also tried to listen for a hiss but ileverything seems fine. Just to add, the car pulls hard and is hitting 22 pounds of boost no problem, it's just this issue that's annoying me. I really hope it's just an exhaust leak. Anyone had similar exhaust leak issues?
Sent from my SM-G935T using Tapatalk
Old 03-09-2018, 07:10 PM   #4
brobst
brobst's Avatar
Drives: CSG mk6 6MT
The boost reading did you get from logging or a boost gauge?
There could be a small line tear somewhere on the boost tap line for example
Old 03-09-2018, 07:16 PM   #5
Noodle
Noodle's Avatar
Got it from my acessport, my intake manifold has never been tapped into, I put my finger over where a boost tap would be and didn't hear or feel anything abnormal.
Old 03-09-2018, 08:59 PM   #6
Noodle
Noodle's Avatar
I just had an idea, could it possibly be my maf? I just installed a new intake filter not too long ago
Old 03-09-2018, 09:45 PM   #7
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Hmm, you can get some maf cleaner and clean it up. When my maf was acting up I was getting some codes. But cleaning the maf is a reasonable idea. It disassembles pretty easily. Just make sure you let it dry before reinstall.
My issue was after new filter was oiled so I suspect oil got on there.
Old 03-09-2018, 10:28 PM   #8
sijray21
sijray21's Avatar
Drives: 2010 TR GTI 6MT 3DR
I had a similar issue when I blew a P2015. It ended up being a broken actuator that was covered under warranty.
sijray21 is offline   Reply With Quote
Old 03-10-2018, 02:04 AM   #9
Noodle
Noodle's Avatar
Broken actuator? You mean wastegate actuator? I'm confused how it would be that if I'm hitting boost fine
Old 03-11-2018, 12:48 PM   #10
Noodle
Noodle's Avatar
So I think I fixed it, I took apart my down pipe and sure enough there was a tiny leak. If anyone is installing a down pipe make sure to order a new oem gasket and 4 new copper nuts so you don't have to take it apart again. I also cleaned my maf and now the issue is gone, cleared the cel and hopefully it never comes back
Old 03-11-2018, 04:13 PM   #11
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I didn't think a leak at the back end would do that. Maybe the maf.
Regardless it works now nice
Old 03-11-2018, 08:27 PM   #12
Noodle
Noodle's Avatar
It was a leak on the actual turbo to downpupe gasket. But yeah no cel yet. Knock on wood
Old 03-13-2018, 07:13 PM   #13
Noodle
Noodle's Avatar
So the check engine light came back on, so annoying because once the cel comes on, the issue is apparent. Once I clear the cel the issue is gone, my codes are p2275 and p0145, they are rich/lean codes for the post cat sensor. I have a spacer on it and I have a stratified tune that apparently disables that sensor. Idk what to do. Is it time to replace the O2? Btw the car has 53k miles
