Old 01-02-2017, 03:41 AM   #1
caddy16v
Drives: 2010 GTI
RNS 510 version?
I have searched and am now more confused! When I power the head unit on and hold down the SETUP button the version screen does not appear. I'm trying to get my RNS 510 to display the bluetooth controls and I'd also like to see what maps are currently installed. I did get a VAG cable when I bought the car but, I really don't think I "should" start playing with the cable with limited knowledge ! Any help is greatly appreciated.
caddy16v is offline   Reply With Quote
Old 01-08-2017, 10:36 AM   #2
MochaD
Newbie
Drives: Mk6 Golf R
I'm wanting to manually update my own unit but as I can't access that menu either I'm going to have to remove the unit, assuming it has never been updated that should give some sort of indication as to which FW/map version is on it. If I had a cable though I'd give it a go myself, after a ton of reading that is.
MochaD is offline   Reply With Quote
Old 01-09-2017, 12:43 PM   #3
CleanAsFckMk6
Drives: 2013 Mk6 GTI
You need to enable the Secret Menu using VCDS.
In VCDS, click Select Control Module
-Then click 37-Navigation
-Click Adaption
-Channel 50 will have a value of 0, change it to 1.
This enables Developmental Mode, which is the secret menu.
Save and exit VCDS.
Reboot RNS and you will then be able to access menu
Mk6 CW Gti - Eurodyne StageII - RSR Clutch Kit - Ultimate Racing TBE - Injen CAI - H&R UltraLows - UR RSB - Rotiform IND-Ts - DieselGeek SS - Eurojet Motor/Trans/Pendulum Mounts - Dark Cherry LED Tails - TDi Front Grill - RNS510 - TT-RS Brake Kit (Not yet Installed)
Looking for VCDS Coding? PM Me
CleanAsFckMk6 is offline   Reply With Quote
Old 01-12-2017, 10:51 PM   #4
caddy16v
Drives: 2010 GTI
-Click Adaption
Save and exit VCDS.
Thank you. And if I'm reading and understanding correctly I need a newer Bluetooth module to accomplish being able to control my Bluetooth device via the head unit.
Old 01-13-2017, 11:57 AM   #5
BarryT82
FIA GT Champion
Drives: 2012 Tiguan & 2013 Passat
I have a newer 9w7 Bluetooth module for sale
BarryT82 is offline   Reply With Quote
Old 01-14-2017, 04:30 PM   #6
caddy16v
Drives: 2010 GTI
Sent PM
Old 01-20-2017, 11:33 PM   #7
Bill@EurozoneTuning
Rally Car Newbie
Drives: 2011 GTI Autobahn
https://eurozonetuning.com/products/...510-and-rcd510
Bill@EurozoneTuning is offline   Reply With Quote
