Old 05-19-2017, 06:11 PM   #15
Calkulin
Calkulin's Avatar
Drives: '13 GLI Nav
You're right, AH is the latest for ours, that revision just stuck in my head for some reason
Calkulin is offline   Reply With Quote
Old 05-19-2017, 06:17 PM   #16
Calkulin
Calkulin's Avatar
Drives: '13 GLI Nav
Originally Posted by FriggenT View Post
I got the latest about 15-20k miles ago...AC iirc
I would double check just to be sure. But if you're having a vacuum leak, try turning on the car with the MAF unplugged to see if that clears up your issue, if it does, then you probably do have a leak somewhere
Old 05-19-2017, 09:17 PM   #17
Fastball
Touring Car Newbie
Drives: CSG 2011 GTI
I posted this on another thread but I replaced the PCV valve a few weeks ago after searching out the cause of oil on the back passenger side of the engine. Several forums suggested a bad PCV could cause a blown gasket or other serious problems. After replacing the wheezing and hissing just about all went away and the car sounded much quieter under acceleration. The part cost $199 OTD and took less than 30 minutes to replace.
Fastball
Carbon steel gray metallic 2011 GTI 4-door w/ sunroof. 6 speed DSG A/T - ECS Turbo Outlet w/ Muffler Delete - VMR V701's Hyper Silver - Floor mat kit - Clear side markers - LED lighting - Under seat stowage bin - unSoundaktored - DEI Soft Chirp Horn - deAutoKey LED turn signals.
Fastball is offline   Reply With Quote
Old 05-19-2017, 10:05 PM   #18
carmaster22
Drives: 2012 GTI 4dr 6MT
funny as i just came from the thread with the guy from new zealand who had to replace his k04 on his R BECAUSE of the africa plate
That wasn't meant to antagonize. It's just funny when something supposed to be a solution
Can you link the thread? I'd like to read through it. I don't have a K04 but I do have the 034 catch can.
carmaster22 is offline   Reply With Quote
Old 05-20-2017, 02:14 AM   #19
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Post #15 references the PCV:
http://www.golfmk6.com/forums/showthread.php?t=110924
2017 Passat VR6
2017 Passat R-line
Old 05-20-2017, 06:20 AM   #20
Mk6 Steve
Touring Car Champion
Drives: 2013 Black GTI coupe DSG
That was a spulen catch can. There africa plate is different. This guy most definitely didnt empty his catch can as often as he should have because the mention of white smoke.
APR Stg 2 V2.4 w/ EMCS, Carbonio Stg 1 + 2 w/ AEM dry-flo filter, APR RSC TBE, Golf R intercooler, 034 Catch Can Kit, Neuspeed TOP audi TT style, Neuspeed charge pipe, GFB DV+ New 3 vent hole revision, Rev D, R8 coils w/ NGK 2667, 034 motor/trans mounts, HPA 75A red puck, TyrolSport subframe and brake stiffening kit, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
Old 05-20-2017, 10:29 AM   #21
FriggenT
Formula 5000 Champion
Ok, I pressure tested my IC last night, and there were no leaks, checked the plug gap which had opened slightly, so I put them back to .0025. There was a fair amount of oil that came out from the IC pipe after pressurizing it...oddly enough I've never had to add more than a half quart at most on the car with the friggen rotella, either way for an "air/oil separator" that thing does a shitty job.
FriggenT is offline   Reply With Quote
