Old 05-18-2017, 07:59 PM   #1
John in Ohio
Drives: 2012 VW GTI Coupe
What's the best tool for Steer Angle Reset in 2012 GTI?
So what's the best tool for that? Foxwell NT510, Carista, PowerLead Cadt PL-ES680, or is there an "affordable" $200 or less Ross-Tech VCDS tool? Or something else?
Many thanks in advance
John in Ohio is offline   Reply With Quote
Old 05-20-2017, 03:08 AM   #2
Carlosfandango
FIA World Rally Car Newbie
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
Any shop with hunter alignment equipment will do the steering angle reset as part of an alignment but you could ask if they'll do it on its own for less money? I've done this myself but using VCDS, not sure if others allow you to do it! Pretty sure you can't do things like that with carista.
Old 06-05-2017, 01:07 PM   #3
MLue1
My OBD Eleven ($60) does have a Steering Angle section but I haven't had cause to investigate further but I know I can do the Throttle Body Reset using the OBD Eleven.
Old 06-06-2017, 11:22 PM   #4
realcyberbob
realcyberbob's Avatar
Drives: 2011 GTI
Send a message via AIM to realcyberbob
Just by Ross-Tech, you can find them used for around $200.
2011 CW GTI 6-Speed: APR Stage II, APR Carbonio Intake, Clutch Masters FX350 Clutch Kit, 42nd Draft Designs Downpipe, Magnaflow Catback Exhaust, Forge Twintercooler, BFG DV+, Dieselgeek Short Shifter, ECS Dogbone Mount Insert, StopTech Pads & Slotted Rotors, Tyrolsport Brake Stiffening Kit, Golf R LED Tail Lights, CiM Vent Boost Gauge, RNS-510 Navigation, Uber-Stealth Box & 10" Pioneer Sub, Alpine MRP-M500 Amp, 25th Ann. GTI Golfball Shift Knob, Modshack Low Profile Engine Bay Trim, Hankook V12
realcyberbob is offline   Reply With Quote
Tags
2012 gti, steer angle
