Old 08-30-2017, 03:41 AM   #113
mostic
mostic's Avatar
Drives: VW
Originally Posted by Edy.Ct View Post
From what I know the R32, MK6 R, MK6 GTI master cylinder is the same. Only the TT-RS cylinder is slightly bigger
http://www.golfmk6.com/forums/showthread.php?t=48777
- 22,22 mm (Mk.V GTI)
- 23,81 mm (Mk.V R32, Mk.VI GTI, Golf R)
- 25,40 mm (RS3 + TT-RS)
Thanks
I will look for it
Old 08-30-2017, 09:16 AM   #114
mostic
mostic's Avatar
Drives: VW
As per TurboZentrum page;
Waiting mine
Old 09-05-2017, 02:18 PM   #115
mostic
mostic's Avatar
Drives: VW
Pics from last VW event;
Painted the R bumpers and will install them with the engine and big turbo swapping.
Old 09-21-2017, 11:43 AM   #116
mostic
mostic's Avatar
Drives: VW
*.* Scirocco R Build! (Fun, Tough & Cost) *.*
Swapped the forged engine with the GTX2867R to the Rocco with most of modified items and the rest will be done later with the EFR installation.
Sorry for the dirty looking but it will have a shower this weekend, I will post a clean one later
I have some sort of items pending waiting to be installed with the EFR kit.
Old 09-28-2017, 04:10 AM   #117
mostic
mostic's Avatar
Drives: VW
Having this error after swapping which was not existed before in the MKV;
Old 10-10-2017, 02:14 PM   #118
mostic
mostic's Avatar
Drives: VW
Quick update; ordered new APR HPFP from USP and will be shipped to a friend of mine in USA and he will bring it to me by end of next week.
Also, installed the oil pressure gauge in my Rocco and will test it tomorrow, will see/share the numbers
Based on the below article -which I donít understand from it anything- I will share the numbers and you can help
Old 10-11-2017, 07:14 AM   #119
mostic
mostic's Avatar
Drives: VW
Oil Pressure 60PSI on idle in the morning when the car is just started;
Oil Pressure 20PSI on idle after driving the car -normal driving- for 45mins;
Any ideas?
Old 10-11-2017, 01:35 PM   #120
mostic
mostic's Avatar
Drives: VW
I checked the oil pressure today at 2000rpm with oil temperature at 80c and below the results;
I guess this is very good by book!
And the error I had has been disappeared after I did the basic settings and tighten it well.
Old 10-12-2017, 01:24 PM   #121
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
Any ideas?
Did you just build your engine? My engine, with 113k miles on it idled at 18-19 psi hot and 50 psi cruising. Remember anything below ~2500 rpm is controlled by the natural pump pressure. The electronic valve doesnít do anything till above that rpm from what I remember.
CLICK HERE FOR MY BUILD
Old 10-12-2017, 01:38 PM   #122
mostic
mostic's Avatar
Drives: VW
My engine just built from 2000-3000kilos almost.
Based on the document that I shared above, supposed to read the pressure @ 2000RPM with 80C and that what I did.
I donít know about the above 2500RPM numbers.
Old 10-12-2017, 03:54 PM   #123
Cadubya
DUBYA
Cadubya's Avatar
What weíre the ring gap specs? Might just be a little tight since itís breaking in.
Old 10-29-2017, 04:12 PM   #124
mostic
mostic's Avatar
Drives: VW
Gapped to 55
Old 10-29-2017, 04:13 PM   #125
mostic
mostic's Avatar
Drives: VW
Just doing some maintenance with my friend
Old 11-22-2017, 10:32 AM   #126
mostic
mostic's Avatar
Drives: VW
Quick update...
Just quick update, I bought R20 AWD gearbox, differential, complete rear suspension, brakes, corona shafts, drive shafts, tank, etc...
The gearbox is already in the scrap yard and the rest will arrive from 2-3 weeks, it is already with low KMs, I will post pics once I have everything in the garage.
