Old 01-30-2016, 01:38 AM   #1
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Tjasko's Golf R Build
I've finally convinced myself to start a build thread... mainly because things are starting to get serious and I can barely fit all my mods in my signature anymore.
I'm not new to these cars; I've had a stage 2 MK6 GTI as well, however I sadly had to part ways with it and a Golf R was my obvious next car. I found the R, went to the used car dealer, test drove it, gave the car a thorough mechanical inspection, and bought it same day back in May 2015. Fun fact: I never even test drove my GTI before buying it brand new, I knew it was exactly what I wanted.
My Golf R is built to be a daily-driven, track-ready car that can have the throttle hammered and be able to take a comfortable, leisurely cruise all at the same time.
Thanks to for everyone below getting things done on the car.
- Auto Union Tuning (shoutout to Raz & Dave)
- Blair Automotive/BMP Tuning (shoutout to Ryan, Blake, & Patrick)
- Robz Auto
- Rotaryknight
HORSEPOWER & TORQUE @ WHEELS:
317hp • 361lbft on APR stage 2+ (Numbers for IE450T kit pending...)
BOUGHT & PENDING INSTALL:
Nothing currently.
WISH LIST:
BFI Shift Knob
Tyrolsport Stage 2 Hatch Brace
ENGINE:
42DD Catch Can w/ AN Fittings & Boost Tap @ 56,497 miles
APR Intercooler @ 57,086 miles
Audi R8 Coil Packs @ 52,960 miles
Autotech High Volume Fuel Pump Upgrade Kit @ 55,608 miles
ECS Engine Oil Dipstick @ 59,928 miles
ECS Street Shield Skid Plate @ 59,928 miles
Fluidampr Engine Damper @ 59,928 miles
GoFastBits DV+ @ 54,172 miles
INA HPFP Cam Follower to Roller Conversion Kit @ 65,013 miles
Integrated Engineering IE450T 93 Octane w/ Intake Manifold Tune @ 71,162 miles
Integrated Engineering IE450T Big Turbo Kit (BorgWarner EFR 6758) @ 71,162 miles
Integrated Engineering IE450T Cold Air Intake @ 71,162 miles
Integrated Engineering IE450T High-Flow Catted Midpipe @ 71,162 miles
Integrated Engineering Intake Manifold @ 71,162 miles
Milltek Catback Exhaust @ 55,608 miles
Neuspeed Turbo Charge Pipe @ 53,627 miles
Neuspeed Turbo Discharge Pipe @ 53,711 miles
NGK BKR7EIX Spark Plugs @ 71,162 miles
Soundaktor Delete @ unknown (was already unplugged)
Turbosmart IWG75 Internal Wastegate Actuator @ 71,162 miles
DRIVETRAIN:
BSH Speedshop Mounts (engine, transmission, pendulum w/ torque mount insert) @ 55,983 miles
DieselGeek Short-throw Shifter @ 55,983 miles
DKM Stage 3 Twin Disk Clutch (rated for ~660ftlb) @ 71,162 miles
ECS Tuning Clutch Bleeder Block @ 71,162 miles
ECS Tuning Stainless Steel Clutch Line @ 71,162 miles
HPA Haldex Competition Controller @ 56,497 miles
BRAKES, TIRES & WHEELS:
Michelin Pilot Sport 4 S Tires (225/35/19) @ 59,928 miles
Motul RBF600 Brake Fluid @ 55,983 miles
StopTech 310mm Slotted Rear Rotors @ 63,756 miles
StopTech Brake Pads Rear @ 55,983 miles
StopTech ST40 Trophy 355x32 Big Brake Kit @ 63,756 miles
Tyrolsport Master Bracket @ 68,549 miles
USP Motorsports Rear Stainless Steel Brake Lines @ 55,983 miles
Volk Racing G25 Dark Silver Prism Wheels (19x8 +48, 18lbs) @ 63,470 miles
Volk Racing ZE40 Custom Mag Blue (18x8.5 +44, 17lbs) - Track Wheels
SUSPENSION:
Bilstein B16 PSS-10 Coilover Kit @ 57,054 miles
Neuspeed Front Sway Bar @ 59,008 miles
Neuspeed Rear Sway Bar @ 53,627 miles
Neuspeed Rear Sway End Links @ 53,627 miles
SuperPro Front Sway Bar End Links @ 59,008 miles
SuperPro Lower Control Arms @ 59,008 miles
SuperPro Roll Control Ball Joints @ 59,008 miles
INTERIOR:
A119 Dash Cam Hard-wired @ 68,795 miles
Escort Max 360 Radar hard-wired with Blendmount @ 57,409 miles
Klii Motorwerkes Steering Wheel Badge Inlay @ 52,270 miles
P3cars Vent Digital Interface w/ analog boost sensor @ 53,517 miles installed
ProClip Phone Holder @ 52,270 miles
R Seat Lever Inserts @ 52,270 miles
EXTERIOR:
APR Hood Decal (EuroCode Tuning threw on some decals for Fastivus 2015) @ 53,760 miles
DeAutoKey LED license plate lights @ 52,270 miles
Klii Motorwerkes Rear Badge Inlay @ 52,270 miles (discovered while doing this rear badge was plastidipped before)
OEM Dark Cherry LED Tails @ 52,270 miles
R Wheel Valve Stem Caps @ 52,493 miles
US Mill Works License Plate Bracket @ 52,864 miles
REMOVED PARTS:
A118-C Dash Cam Hard-wired @ 59,048 miles installed & 68,795 miles removed
APR Boost Tap @ 53,532 miles installed & 56,497 miles removed
APR Stage 1 tune (just transferred the warranty) @ unknown (came with car) & 55,608 miles removed
APR Stage 2+ Tune @ 55,608 miles installed & 71,162 miles removed
Continental DWS Tires @ unknown (came with car) & 59,928 miles removed
Deutsche Auto Parts HPFP Stud Kit @ 59,008 miles & 65,013 miles removed
Eurotek 19” 02 Wheels @ unknown (came with car) & 63,470 miles removed
EZ Lip Pro @ 57,211 miles installed & 59,392 miles removed
Milltek Downpipe @ 55,608 miles installed & 71,162 miles removed
Neuspeed Intake @ 53,627 miles & 71,162 miles removed
Neuspeed Race Springs @ unknown (came with car) & 57,054 miles removed
NGK PFR7B Spark Plugs @ 64,220 miles & 71,162 miles removed
South Bend Stage 2 Daily Clutch @ 54,275 miles & 71,162 miles removed
StopTech Performance Brake Pads Front @ 55,983 miles installed & 63,756 miles removed
[My .:R IE450T Big Turbo Build Thread] | Parts from: APR, Bilstein, IE, Neuspeed, Milltek, Volk Racing, StopTech, SuperPro, USP, 42DD, BSH & more
tjasko is offline   Reply With Quote
Old 01-30-2016, 02:07 AM   #2
Trytun
Trytun's Avatar
Drives: 13 CSG
Definitely a beautiful ride! Lemme know how you like the APR IC when you get it on. I'm debating between that and the Neuspeed!
I bought my GTI in May of 2015 as well. I was like you in a way, I test drove a CW autobahn and liked it but didn't want the leather so I did a full mechanical inspection of the one right next to it, a base model, and bought it.
Unitronic Stage 2/Unitronic Stage 1 DSG Tune/APR Downpipe/Neuspeed Catback/Miro Shit Wheels/30% all around/Solo Werks S1 Coilovers/TTRS Strut Mounts/Unitronic Intake/Unitronic Intercooler/Soundaktor Delete/GFB DV+/R8 Coils/Spulen Discharge Pipe/Spulen Turbo Muffler Delete/034 Motorsports Billet Insert/034 Motorsports Street Density Motor and Trans Mounts/ECS Tuning Rear Sway Bar THE BUILD THREAD
Trytun is offline   Reply With Quote
Old 01-30-2016, 02:10 AM   #3
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Thanks man! Absolutely love this car.
I've had the APR intercooler on my GTI & loved it. Which is why I'm installing it again. However Neuspeed makes a great intercooler too. Both keep the temps down nicely when compared to stock, so you can't go wrong with either; matter of preference really.
Old 01-30-2016, 02:12 AM   #4
robeeeerob
robeeeerob's Avatar
Drives: 2013 CW GTI (DSG)
sub'd!
A WOT a day, keeps the carbon away
robeeeerob's Build
Need an install or auto service done?RobzAuto
robeeeerob is offline   Reply With Quote
Old 01-30-2016, 02:16 AM   #5
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Originally Posted by robeeeerob View Post
sub'd!
Old 01-30-2016, 03:47 PM   #6
vizzlebizzle
Drives: 2013 R
how long have you been 2+? definitely on my list, and i've been eyeing that autotech upgrade the closest as well. clean car, i've always liked those style wheels too.
TRAP LORD
My 2013 R journal - EVOMS - 42DD - Neuspeed - Unitronic Stage Dos+
Memories: 2005 Evolution VIII, 1997 240SX, 1993 240SX
vizzlebizzle is offline   Reply With Quote
Old 01-30-2016, 03:56 PM   #7
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Tjasko's Stage 2+ Golf R Build
Thanks! My car definitely screams my personality lol. Ohh yeah, I love the look of the wheels, they're just a big pain to clean.
I've been 2+ for about three months or so. I'd highly recommend it; it will chew up more gas when you give it, but boy does it change the dynamics of the car. My R boosts significantly higher as well, at a 30.5psi in the most perfect conditions.
I have no regrets with the Autotech upgrade and I'm glad I didn't spend a fortune for APR's HPFP. And it plays perfectly with the tune, only thing is it's recommended to change your can follower every other oil change (for me that's 10k).
Old 02-02-2016, 08:34 PM   #8
MK6 Shizz
MK6 Shizz's Avatar
Drives: CSG 2013 MK6 GTI Autobahn
I spotted myself in your thread! Great build! Keep it up!
"I have a fear of speed bumps.... I'm slowly getting over it..."
Click pic for Project Scarlett Build Thread
MK6 Shizz is offline   Reply With Quote
Old 02-03-2016, 02:32 AM   #9
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Hehe, yeah, after I did some touchups to that image in Photoshop I had to use it because it was too good.
PSS-10s will be going on Saturday the 13th.
Old 02-08-2016, 05:44 PM   #10
MK6 Shizz
MK6 Shizz's Avatar
You gonna come to the meet to show off the coilovers?
Old 02-08-2016, 05:50 PM   #11
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
I'm coming to the Monday meet, but Raz had to move the install to this weekend as he was too busy (like expected, they didn't want to set up an appointment until they actually received them, which was on Thursday). This weekend is a set date, so I'll have 'em Saturday afternoon.
So I'll at least have them for Last Sunday. Hopefully they receive my intercooler soon as it's supposedly on back order from APR... so I can have both in time for Last Sunday.
Old 02-13-2016, 12:26 AM   #12
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
My APR intercooler is installed. Initial impressions are way better than I was expecting. The performance of the car is easily ~20hp more and the car hauls some serious butt. I had no idea it was that much of an airflow restriction.
Bilstein PSS-10s going on tomorrow.
Old 02-13-2016, 06:38 PM   #13
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Bilstein PSS-10 coilovers installed. Two words: holy shit. It rides significantly better than my previous setup (just Neuspeed race springs) and handling has been significantly improved. Totally worth the money... and the car is at the perfect height now as it's not scraping on my driveway!
I'm very excited to feel how it performs up in the canyons and on the track.
Old 02-13-2016, 10:44 PM   #14
robeeeerob
robeeeerob's Avatar
Good stuff taylor!!
robeeeerob's Build
450t, build, golf r, ie450t
