Old 10-05-2010, 01:55 AM   #1
hpa-gtii
Drives: MK6
downpipe alternative, need your opinion
What do you think about taking the oem downpipe and cleaning out the first catalytic converter? That way only the second CAT will be in use and the whole setup will look oem because nothing is changed on the outside. I could also get APR Stage 2 software to take care of any CELs. Your opinion please.
hpa-gtii is offline   Reply With Quote
Old 10-05-2010, 02:07 AM   #2
Axleman
Axleman's Avatar
Drives: 2010 GTI 4 Dr DSG
Send a message via Skype™ to Axleman
1) Hollowed out cats sound like crap. A big hollow can attached directly to the turbo outlet would probably sound really bad.
2) I bet it wouldn't flow much better either. 3" Turbo outlet to 5-6" hollow can to squished 90 degree turn doesn't sound like it would work very well.
3) When you go to stage 2, most of the gains you get are from the downpipe replacement, very little comes from the software upgrade. I don't see any benefit with what you propose. Sorry.
http://www.fuelly.com/driver/Axleman/gti
2010 Tornado Red GTI, 5 Door DSG, APR Stg 2, subject to catastrophic failure at any moment (according to harddrivin1le)
2010 Salsa Red Jetta TDI Sedan, 6 speed
Axleman is offline   Reply With Quote
Old 10-05-2010, 02:08 AM   #3
euro89
euro89's Avatar
Drives: CW MK6 GTI, Manual
Thumbs up
USP catless 3"
*** M Y - P R O J E C T***
euro89 is offline   Reply With Quote
Old 10-05-2010, 02:46 AM   #4
hpa-gtii
Drives: MK6
What about removing the first CAT and replacing it with a pipe? Thanks for responding.
Old 10-05-2010, 02:51 AM   #5
OverTimer
OverTimer's Avatar
Drives: 13 PG GLI Autobahn DSG
Send a message via Yahoo to OverTimer
If time is money that's a waste of both.
You spent at least 23 on your car why cheap out now?
OverTimer is offline   Reply With Quote
Old 10-05-2010, 10:48 AM   #6
Axleman
Axleman's Avatar
Have you seen the factory downpipe and how the precat is made into it? It doesn't look like it would be very practical or easy to try remove it from the factory pipe. I suppose you could have a shop fabricate the upper portion of the downpipe and weld it to the rear section where the second cat is. But the whole point of replacing the downpipe is for increased flow and this approach only goes halfway really.
What exactly are you trying to accomplish?
Old 10-05-2010, 10:56 AM   #7
plac
Guest
Posts: n/a
people have tried to clean them out. huge pain, and if you leave any particles in there they can get broken loose and sucked in on decel. overall just not a good plan any way you look at it. better off buying a $150 ebay pipe and testing it out if youre gonna do that. no advantage to "look stock" with your oem downpipe when you can't pass emissions anyway.
Old 10-05-2010, 11:22 AM   #8
hpa-gtii
Drives: MK6
I want a dp that not restrictive like to oem and I want the quietness of the oem pipe diameter. I want the AWE pipe but I don't like their 1 year warranty.
Wouldn't it run like the AWE dp?
Old 10-05-2010, 11:25 AM   #9
plac
Guest
Posts: n/a
Very good points. The pipe size doesnt have as much relation to noise as the cats and resonators do. There are a few other options for a catted/resonated downpipe aside from AWE which is the highest priced. (42dd, Ultimate Racing come to mind.)
Old 10-05-2010, 11:38 AM   #10
Axleman
Axleman's Avatar
Probably not since the exhaust must still go through a very dense factory cat. The AWE pipe has a high flow cat. FWIW, any mod you would do on the factory pipe would kill the warranty on it, so I'm not sure why AWE's 1 year warranty would bother you.
I think plac is right though. Get one that is catted and resonated to keep things quiet.
Old 10-05-2010, 12:00 PM   #11
hpa-gtii
Drives: MK6
So Plac, you're saying that pipe diameter does not affect sound only cat and res?
Old 10-05-2010, 12:02 PM   #12
hpa-gtii
Drives: MK6
I don't like AWE's 1 year warranty.
Old 10-05-2010, 12:17 PM   #13
plac
Guest
Posts: n/a
no, thats not what i said, if you read it carefully.
