Old 10-05-2010, 01:29 PM   #1
Shieze
Drives: 5DR DSG CSM 2011 GTI
2011 GTI stalling
SO I have had my new car for less then a month and I have had a problem intermittently about 8 times so far.
Basically when I am starting the car it will sometimes start idling very low 500rpm then stall.
I have also had the above happen and I have hit the gas to bring the rpms up but shortly after driving I have tried to accelerate and the car is in neutral as the revs just go up freely. Changing it from Park to drive resolved this.
Do I have a problem with my DSG? I first experienced the stalling a couple of days after picking up the car.
Shieze is offline   Reply With Quote
Old 10-05-2010, 01:33 PM   #2
pedobear
Drives: TDI Golf
Maybe a computer issue.
pedobear is offline   Reply With Quote
Old 10-05-2010, 02:09 PM   #3
plat
plat's Avatar
Drives: 2016 Audi S5
Yeah, seems like its either the ECU or the DSG Mechatronics unit.
plat is offline   Reply With Quote
Old 10-05-2010, 03:16 PM   #4
AutobahnGTI
Keyless start? Hold the button down longer. That is what I was experiencing and it resolved that problem.
AutobahnGTI is offline   Reply With Quote
Old 10-05-2010, 03:21 PM   #5
71Fritz
71Fritz's Avatar
I have had this a few times. I have a manual and only notice it when I am parked in the garage. Seems if I park to close to the wall, when I start it sputters almost like it's not getting enough air. I'm no expert so can that be a reason?
71Fritz is offline   Reply With Quote
Old 10-05-2010, 04:03 PM   #6
Shieze
So my car is not a keyless start.
I have had the problem in open parking lots so this is definitely not causing my issue.
Thanks for all the replies.
Old 10-05-2010, 04:20 PM   #7
AutobahnGTI
Hold the key turned longer. It's because 1 of the cylinders is not fired up.
Crank it longer.
Old 10-05-2010, 04:24 PM   #8
Shieze
Crank it longer.
This doesn't sound right to me. As the car is still running for a few seconds I would think that one cylinder would fire up on the next point when the spark plug would ignite, unless the computer is doing something wrong.
Old 10-05-2010, 04:35 PM   #9
AAU
AAU's Avatar
I only had it happen twice in my manual, both times were on the first tank of gas from the dealership.
Ride too rough? See Test drive, How to Sell a Car, Sport utility vehicle
AAU is offline   Reply With Quote
Old 10-05-2010, 07:44 PM   #10
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
My 2011's done this about 3 times now..twice on the same day (day after I got the car). I figured I didn't turn it over long enough though. I crank it for a fraction of a second longer and haven't had that issue.
My mom's grand prix has an issue where if I turn it off and start it within a short period of time 5-10 mins it would crap out the first time.. not too sure on the cause. Otherwise that cars been fine for the last 8 years.
Just read the above post... my thoughts exactly....
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 10-06-2010, 11:22 AM   #11
Shieze
I have an appointment booked for next week. Putting on winter tires and getting a few warranty things looked at this being one of them.
I also have the leaking rear window washer and a couple of other things.
Old 10-06-2010, 02:10 PM   #12
snofrandy
snofrandy's Avatar
Drives: '10 GTI
That's weird. I have a 2010 w/ DSG and I just let the computer control the starter. Basically, when I start the car, I briefly push the key in igniton to "Start", then release right away. This is all in a fraction of a second. There's a split second lag, then the ignition would start the starter, engine would turn over automatically, starting the car. I think the amount of time the starter needs to run to completely start the car is automatically controlled by the ECU. Meaning you don't have to hold the key in "Start" position until the car starts.
The only other way I can describe this is the push button start for Lexus when I was test driving it. Push Start and release, Starter will start a split of second after release.
This is unlike my previous car where I have to hold the key in the Start position until the engine turns over and start. Where as if I do what I'm doing w/ the GTI now, as soon as I release it from "Start", the engine would die right away because the starter is controlled by the ignition switch.
1991 Corolla > 2004 Corolla > 2010 GTI > 1994 Miata
Candy White : DSG : Interlagos : 9W7 : 55%F/18%R Tint : Clear Bra : DDM Tuning 5k LB and 3k Fog : EVOMS V-Flow Intake : OEM Cherry Red LED Tail
snofrandy is offline   Reply With Quote
Old 10-06-2010, 02:18 PM   #13
koolgreen
koolgreen's Avatar
Drives: 2011 CSG 6mt detroits
Crank it longer.
Never crank an engine after it has caught or you will have flywheel teeth flying off into oblivion...........
koolgreen is offline   Reply With Quote
Old 10-06-2010, 02:18 PM   #14
Shieze
Thanks. From your description this is completely controlled by the computer then and should have nothing to do with how long you hold the key.
