Old 07-05-2011, 05:11 PM   #29
ZCulture
Drives: 1996 300ZXTT, 2011 autobahn 4dr GTI
My dealer confirmed that this is an issue that
they have seen before and VW is aware of it. They don't have a solution yet.
ZCulture is offline   Reply With Quote
Old 07-05-2011, 06:48 PM   #30
AdamC
AdamC's Avatar
Drives: '11 4D GTI DSG CSG
I had this happen like 3 times when I first bought the car. I think my cheap salesman threw 87 in there to fill it up after I reamed him on the price (kidding) but it seems to have disappeared by now. It was very unsettling for me the first time it happened to say the least.
AdamC is offline   Reply With Quote
Old 07-05-2011, 07:18 PM   #31
SwiftGTI
SwiftGTI's Avatar
I've had this happen to me three times in the first ~1000 miles. Doubtful it's related to octane because the last two times occurred with quality 93 gas. The first two times, the engine quickly regained a stable idle on its own, but the last time, I had to press the gas slightly to bring the RPMs up to normal. This doesn't bother me much considering it doesn't seem to be a huge issue, but if it gets worse, I will bring it to the dealer to fix under warranty.
SwiftGTI is offline   Reply With Quote
Old 07-05-2011, 10:01 PM   #32
nekkehd
Drives: mk6
shoulda gotten the manual
Mods- Apr carbonio intake, Forge blow off adapter, Ultimate racing down pipe, giac stage 2, bfi stage 2 mounts
Upcoming- tires+wheels, brakes, suspension, boost gauge, stage 2 clutch, water meth.
nekkehd is offline   Reply With Quote
Old 07-05-2011, 10:58 PM   #33
VWTN
Drives: GTI
2011 GTI DSG owner:
Happened the day I brought it home, twice. Unsettling is a good word. Hasn't happened since (disclaimer: I've only had the car 48hours as of right now) but definitely not something I was expecting.
On the 3rd crank I tapped the gas a little and it hung on. It seemed like a low idle. Car had 302miles when I bought it (about 100 were transporting to the dealership) drove it home the odometer read 375 when it happened to me.
VWTN is offline   Reply With Quote
Old 07-06-2011, 08:08 AM   #34
SwiftGTI
SwiftGTI's Avatar
Happening to manual GTIs as well.
Old 07-06-2011, 02:14 PM   #35
sethmark
Drives: 11. Black.
VW is aware of the problem and is actively working for a
solution. In my car it was a problem I could nearly cause at will. I suspect it's computer related.
sethmark is offline   Reply With Quote
Old 07-12-2011, 04:20 PM   #36
ikerumba
Drives: 2011 GTI AUTOBAHN Charcoal Grey DSG
I purchased my 2011 GT1/DSG/Autobahn /keyless_start on April 11.
Symptoms:
Start is very inconsistent and feels very weak.
When I pull out of the driveway, I put in reverse and take my foot off the brakes, and sometimes the car doesn't move unless I give it gas. Other times the engine stops all together after backing out a couple yards. Other times, it is totally fine.
Took it it to dealer on June 13th and they found a fault in their diags and they replaced part called Terminal 15 Relay #J329.
I do not think that fixed it cause it now is showing the same symptoms again. I am planning on taking back to dealer next week.
Odometer as of today is 2700.
ikerumba is offline   Reply With Quote
Old 07-12-2011, 05:39 PM   #37
Wicked
Wicked's Avatar
I'm in the same boat here... I have the manual with keyless start. I have to hold the starter button in till I get a good crank. If I just tap the button it tries to start but sputters and usually stalls.
Car is 8 days old, 500 miles.
On my wifes car (IS350), you just hit the start button and get a perfect start every time.
Either way I can live with it. The leaking washer fluid on the rear window is driving me nuts though.
Wicked is offline   Reply With Quote
Old 07-12-2011, 06:09 PM   #38
ShadowBlueGTI
Drives: 2011 Shadow Blue GTI
I posted a topic about this a few weeks ago. I thought maybe turning the A/C off before I started the car was the cause of the problem?
ShadowBlueGTI is offline   Reply With Quote
Old 07-13-2011, 11:59 AM   #39
abmGTI
I have a manual and this happened to me in my parent's driveway which has an incline. Maybe if the car is on an incline, the fuel pump is not properly primed.
abmGTI is offline   Reply With Quote
Old 07-13-2011, 12:40 PM   #40
VW-TX
VW-TX's Avatar
Drives: 2011 GTI AutoBahn, DSG, Candy White
Originally Posted by Shieze View Post
SO I have had my new car for less then a month and I have had a problem intermittently about 8 times so far.
Basically when I am starting the car it will sometimes start idling very low 500rpm then stall.
I have also had the above happen and I have hit the gas to bring the rpms up but shortly after driving I have tried to accelerate and the car is in neutral as the revs just go up freely. Changing it from Park to drive resolved this.
Do I have a problem with my DSG? I first experienced the stalling a couple of days after picking up the car.
Mine does this too and no one can figure out why. I give it some gas when it is trying to die and it fixes itself. Happens pretty often, but not often enough for the dealer to see it happen.
2015 Chevrolet SS Sedan, Heron White, A6, w/roof and spare
SOLD: 2015 Golf R, DSG, Lapiz Blue, DCC and NAV.
VW-TX is offline   Reply With Quote
Old 07-13-2011, 01:21 PM   #41
sethmark
Drives: 11. Black.
Again, I know for CERTAIN that VW has the problem on their radar.
Question for those that are having the problem, does it seem to be only when the car has been driven then has sat for a couple of hours or is the problem random?
Old 07-13-2011, 11:17 PM   #42
VW-TX
VW-TX's Avatar
Not cold or hot but always after a few minutes to maybe a few hours after sitting it does it.
