Old 12-13-2017, 05:26 PM   #225
DaveGLI
Drives: Mk6 GLI Autobahn, B6 A4 2.0L 3076R
Originally Posted by brobst View Post
When you figure out the fueling charts for your new injectors in eurodyne, would you mind sharing here?
Edit: I read up again. I see you got the mk7 injectors and port injectors as well. Thats different I guess in how the fueling charts will act vs just 4 injectors.
Can you better explain what it is you're looking for?
Fueling charts? you mean the what injector constant is being used on the Mk7 Injectors? or the ZZP's?
Btw, ZZP's were switched for Mk7 due to better spray, and fitment into the Manifold. ZZP's are kinda a bitch and we had issues with misfires on cold start.
or are you looking for the main fueling tables?
(hi.. I tune the car..)
- IE EFR GLI -
DaveGLI is offline   Reply With Quote
Old 12-13-2017, 06:12 PM   #226
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Maybe I don't fully understand eurodyne yet, since I haven't done fueling changes yet myself. I see there is an injector constant, which you change. Are there some other tables as well that have to be changed when you change injectors?
I'll pm you dave. I'm trying to figure out what to do about fueling to get full e85 on my k04.
Old 12-14-2017, 01:45 AM   #227
DaveGLI
Feel free to PM Me, but the chances of you having sufficient fuel to do a full E85 file are highly unlikely especially on a K04.
You may be able to get away with a mix but its not something you actually want to do without some means of monitoring content. Regardless, it's a poor idea.
And yes, Eurodyne does have an injector constant that needs to be adjusted if you change out to a different DI Injector, and then as for port fuel adjustments you would need to do significant modifications to make the car integrate with it correctly, which is mostly a large majority of MAF adjustments.
It's not as simple as it sounds...
- IE EFR GLI -
Old 12-30-2017, 02:51 PM   #228
blackwrath88
blackwrath88's Avatar
Drives: Shadow Blue MK6 GTI
Did you ever get a chance to dyno the car? Please post some #'s please.
blackwrath88 is offline   Reply With Quote
Old 12-30-2017, 04:19 PM   #229
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Dyno coming up this winter. Car has been apart for the Walbro 450 custom LPFP basket, custom headlights, port fuel meth changes and a few smaller updates. By next weekend the car should be on the ground and ready to road test the following:
-headlight lighting controls
-direct port meth layout (check for leaks)
-port fuel injector output with the new Walbro 450 LPFP
-new Eurodyne file with 27psi peak and higher timing (this will be my 93 octane pump gas file I'll look to dyno)
Only problem is the cold snap we are in. RE-71Rs do not like sub-freezing roads.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
