Old 02-12-2016, 10:54 AM   #1
Jimd0313
Jimd0313's Avatar
Drives: 2011 MK6 GTI - Autobahn, UG
Bulb out errors with LED reverse lights
Hey all. I've recently received a set of the new style LED reverse lights from deAutoKey to use, and they are causing a bulb out error. I've got ED LED tails, with byte 18 coded to 1F to remove errors.
There are no error with the factory bulbs, but as soon as I change them out and start the car, I get the error for both. They still work fine but are causing the error message.
DeAutoKey customer service has been great, but they seem pretty stumped and seem to think it has something to do with the coding. They are going to send me resistor boxes, but I really was hoping to use these without.
Anyone experience anything similar with LED tail lights? If so, what was your solution? Thanks for the help!
Jimd0313 is offline   Reply With Quote
Old 02-12-2016, 01:26 PM   #2
relic1
relic1's Avatar
Drives: '12 6sp GTI
when I first dropped in my LED reverse lights I got a bulb out light.
I checked coding, reset what I could... didn't help. It took letting the car sit overnight (till I had time to look into the problem further) started the car, no light.
I also had reverse bulb out error when I swapped one of my front turn signals back to stock from deAutoKey's LEDs.
That took replacing both front turn signal bulbs back to stock to get the error light to turn off.
With my car, it seems the default for anything strange/changed_since_last_test in the self test startup routine path... it sets the reverse light code.
relic1 is offline   Reply With Quote
Old 02-12-2016, 01:33 PM   #3
WetMoney
WetMoney's Avatar
vagcom if you have someone local that can help you.
just have to change a setting.
there is a setting for front and rear bulb saver. just turn it off.
Old 02-12-2016, 04:40 PM   #4
Jimd0313
Jimd0313's Avatar
Great, thanks! Is that setting in 09 Central Electronics?
Old 02-12-2016, 07:50 PM   #5
leiito
leiito's Avatar
Drives: 2010 Golf GTI 2-door 6mt
I could never find a fix for this. Gave up on it a few years ago and just live with the light coming on every now and again.
leiito is offline   Reply With Quote
Old 02-13-2016, 03:02 PM   #6
UMassGTI
Drives: 2011 Black GTI
Had an error ever since install. Running with the bulb out error for now but it drives me crazy. Purchased deautokey because all my other bulbs from them didn't give an error
Freektune Stage 2
UMassGTI is offline   Reply With Quote
Old 02-13-2016, 05:00 PM   #7
deAutoLED.com
GolfMK6 Official Vendor
deAutoLED.com's Avatar
Drives: VW
Hi, sorry to hear this for sure, we need more info to troubleshoot this.
When did you buy our LEDs month/year - we can figure out the exact model as our older model from a few years ONLY required resistors, the new setup doesn't.
When did you see this issue, right after install, a month after?
Any other mods in your car? Cars that have different VCD settings can trigger errors in our reverse.
Does your car have fog/reverse or 2 reverse?
Which aftermarket Tails are you using?
When does the error happen? The car MUST be started, it cannot be in accessory mode or not started when you use the reverse - if you do this you must reinstall regular bulbs sometimes to reset the codes.
What side is this happening on, left/right - try switching the bulb from one side to another, does the issue follow?
It could be: VCD Coding, using reverse without starting car, a bad resistor on our LED, or a loose connection, when you wiggle out the glass bulb it stretches out the prongs as they have play, press them together and then install our LED, this will create a tighter fit.
What this might be is a loose connection, when you start the car it isn't picking up the light voltage and could throw a code, simply tightening the prongs can fix this.
If everyone can post the info above neatly we can better help and figure this out:
-When did the errors start
-was the car started or in accessory mode
-year/make/mode
-what type of aftermarket LED tails
-what side is causing the errors - did you switch the LED.
-Does your car have fog/reverse or 2 reverse?
We apologize for the inconvenience, we have these installed in hundreds of cars and we only had a few issues with errors, normally always fixed by tightening prongs or replacing the LED (bad resistor but rare that happens).
Please keep us updated.
Thank you
deAutoLED.com is online now   Reply With Quote
Old 02-13-2016, 11:19 PM   #8
UMassGTI
Errors began immediately following installation and start-up. 2011 GTI W/DSG. Depo led tails. Left reverse bulb always throws code, but the right bulb has thrown as well on occasion. No fog, just reverse.
Freektune Stage 2
Old 02-15-2016, 11:43 AM   #9
Jimd0313
Jimd0313's Avatar
-year/make/mode
-I just purchased mine within the last month.
-The first time I installed them, I put it into accessory mode to test. After speaking with your customer service, I reinstalled factory bulbs to clear the error and then reinstalled the LED's. Started the car, and the error came back on within 5 seconds or so.
-2011 GTI Autobahn (Xenons)
- ED Tails, VCDS coded for no errors (Byte 18 coded to "1F" in central electonics). No other VCDS changes.
- Both sides are causing the errors. I've turned the bulbs around in the socket, and switched sides. No changes.
-2 Reverse lights on mine, no fog.
I'll try checking the tightness of the prongs, but both sides seem to fit pretty snug.
Just to reiterate what I stated in the DeAutoKey feedback thread, I've been very happy with your customer service and the other LED's I installed from you guys!
Old 02-15-2016, 06:13 PM   #10
deAutoLED.com
Drives: VW
Ok, do both of you have VCD coding that is different than standard coding with these?
The only way these will throw a code is if the car is sending out different voltage which can happen with vcd coding, it is rare this to happen.
If you send an email with more info the only options would be:
- send new ones to test
- return for a refund
- install resistor/taps
Support@deAutoLED.com
Thank you
Old 02-15-2016, 06:59 PM   #11
deAutoLED.com
Drives: VW
Hi, I was speaking to deAuto - please email Support@deAutoLED.com with your order # and they will get you setup with a new setup to see if it help. They are in the warehouse and ready to help - everything can be out tomorrow.
Thank you
Old 02-16-2016, 08:55 AM   #12
Jimd0313
Jimd0313's Avatar
I've just got the standard "1F" coding for my tails.
I just emailed the support email with my order number. Hopefully I've just got a bad set. If not, I'll have to install the resistors, but would really prefer not too.
Thanks for your help!
Old 02-28-2016, 09:16 PM   #13
Jimd0313
Jimd0313's Avatar
Just an update for anyone who experiences a similar problem. They sent me new bulbs of a slightly different style and they work perfectly. DeAutoKey customer service was fantastic throughout the process! Great company to work with!
Old 02-28-2016, 09:19 PM   #14
UMassGTI
Same with me, great customer service experience. Thanks DeAutoKey!
Freektune Stage 2
