Old 05-23-2016, 01:33 PM   #15
So some do the aluminum front arms, but who has done the rears? My parts arrived and these are so light! The dust covers left all these great bolts behind.
Old 05-24-2016, 12:34 PM   #16
Run rabbit, run.
Old 05-25-2016, 12:23 PM   #17
mg_90
mg_90's Avatar
Drives: 11 GTI
Those aluminium rear spindles seem quite a good upgrade, I may do them while installing the coilovers, just want to know if you could answer some questions about them.
- Do they increase track width?
- Do they require longer bolts to attach them to the control arms? Maybe since the are made of aluminium that part is thicker and needs a longer bolt like in the front spindles for the brake caliper carrier.
Thanks in advance
mg_90 is offline   Reply With Quote
Old 05-25-2016, 03:25 PM   #18
Yes, I know I'll need the longer Passat caliper bolts. I haven't checked the rest of the hardware but I'm making an order list. Want to get everything at once to save on shipping. I'll update the thread with part numbers.
Here are the original Detroits with TPMS. They are for sale and I'll consider parting out individual wheels.
Old 05-25-2016, 03:40 PM   #19
nafljhy
Drives: 2011 UG GTI
nice build zrickety! quick question, whats the benefit of the enlarged hole in your skid plate?
Old 05-25-2016, 04:19 PM   #20
Thanks N! The hole makes oil changes a snap and for better air flow.
Old 05-27-2016, 07:36 PM   #21
Did an oil change today, giant hole made it a breeze. Airport run tomorrow to get my Dad. I have some pics but Tapatalk is not working for me.
Edit
Garage Mahal under construction
Old 06-05-2016, 05:03 PM   #22
Garage assembled. Now to wire up the electric and grade some dirt.
Old 07-16-2016, 11:33 AM   #23
More pics for the memories. 220' pvc and a flat tire. 117800 miles.
Old 07-16-2016, 01:04 PM   #24
Anybody do trackdaze? I'm looking at Road Atlanta in October, or VIR in November...
Edit- registered for HPDE Nov 3-4 at VIR
Old 07-18-2016, 12:03 PM   #25
So I did comparisons between the GTI and Passat/Tiguan rear knuckles...most of the bolts are the same, including the calipers. The top and bottom toe arm bolts are longer, 115mm vs 95mm. You'll need 4 total.
Part number N91076701
https://www.ecstuning.com/ES471835/
Mg_90 tipped me that the bolts for the trailing arm are longer as well, 40mm. You'll need 4 of those too. N10628401
He also tells me that we gain 10mm track width each side, for 20mm total increase.
Complete REAR hardware for Passat upgrades
N91076701 x4
N10628401 x4
For the aluminum fronts, you need longer pinch bolts, caliper bolts, and I opted to get new Passat ball joints with nuts. You'll also need a couple flange nuts on the tie rods that I forgot to order before. To my disbelief, it looks ECS tuning now has free shipping with no minimum!!
Nuts part number N10106402
Edit- complete FRONT hardware list for Passat upgrades
N10106402 x4
N90954802 x2
N91084901 x4
3C0407365A Febi left ball joint, includes nuts
3C0407366A Febi right ball joint
Old 08-10-2016, 04:59 PM   #26
Kids start school next week, so hoping to do some suspension work.
120k service coming quick. Here are the plugs I run for reference. Denso Platinum TT, less than $5 each.
Old 08-11-2016, 12:06 AM   #27
senseless1707
senseless1707's Avatar
Drives: 2014 GTI Wolfsburg Edition
Killer garage setup! done a great job since acquiring the MK6.
My 2014 CW Build Thread
senseless1707 is offline   Reply With Quote
Old 09-30-2016, 04:58 PM   #28
So today is the day. I'm ripping into my suspension. Aluminum rear housing weighs 3 lbs less (13.2 vs 16.2). I've got one side going back together with new mounts, DG springs and Koni. Stock shocks and Pro springs out! Long weekend ahead.
