Old 03-04-2016, 05:45 PM   #1
visceralsoup
visceralsoup's Avatar
Drives: 2013 VW GTI (sold), 2012 Golf Arrrr
Testing with ethanol
Hey guys, interesting results from the dyno last night.
Im using UM stage 2 fully loaded
On 91 octane I can safely run at a setting of 88 octane through VCDS.
I pumped about an "e25" mix in and was able to run at 98 octane.
Ran my car back to back with these octane settings on a dynapack.
Just so you get an idea on this dyno a stock 335i made 230whp.
313whp and 368tq. Not bad!
That means a solid 30whp and 30tq across the board just by adding a couple gallons of e85
2 MOJITOS, STAT!- Thad Castle
Turbo Ranger Build
visceralsoup is offline   Reply With Quote
Old 03-05-2016, 04:29 AM   #2
Pmanpop
Pmanpop's Avatar
Drives: 2011 Vw GTI
Very solid! I've been tired of inconsistent pump gas so I'm running a e25 blend (roughly 93 octane). Pulls night and day difference. Glad you have data to back it up.
Old 03-05-2016, 04:52 AM   #3
Turbo Beetle
Drives: 2012 Turbo Beetle
When you posted
"I pumped about an "e25" mix in and was able to run at 98 octane."
Did you check for timing pull and if you did what were the results.
If you did not have any timing pull at 98 octane did you try a 100 octane file? Thanks for posting your dynos.
Turbo Beetle is offline   Reply With Quote
Old 03-05-2016, 07:19 AM   #4
visceralsoup
Originally Posted by Turbo Beetle View Post
When you posted
So according to Jeff Atwood from UM anything over 3 degrees pull is not recommended. At 98 octane I saw 1.5 degrees at MOST. Below that it was zeros across the board!
Turbo Ranger Build
Old 03-08-2016, 11:01 PM   #5
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
Not bad dyno numbers! Extremely close to what I get on 91 pump gas.
[My .:R Stage II+ Build Thread] | Parts from: APR, Bilstein, Neuspeed, Milltek, Volk Racing, StopTech, SuperPro, USP, 42DD, BSH & more
tjasko is offline   Reply With Quote
Old 03-09-2016, 09:55 PM   #6
visceralsoup
Yeah I was pretty happy with how it turned out. I still think the dyno reads a bit low but this was more for testing changes with ethanol via VCDS
Turbo Ranger Build
Old 03-09-2016, 11:13 PM   #7
GIACUser
GIACUser's Avatar
Drives: 2008 MKV EFR7163
Its about the gains, nice gains! Thanks for posting your results.
| 2008 GTI under construction as of July 2017 | EFR7163 | LSD | DriverMotorsport tune | UNI custom DSG tune | Aquamist W/M | Brembo brakes f/r |
| YCW Coilovers | fifteen52 fender flares | 18x9.5 RPF1 w265/35 Michelin SportCup2 | Recaro Speedseats |
Old 03-10-2016, 01:40 AM   #8
visceralsoup
Yessir!
Turbo Ranger Build
Old 03-10-2016, 04:16 PM   #9
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
Very cool. I wish Uni, Revo and APR would come out with e85 blended ots maps.
mamock116 is offline   Reply With Quote
Old 03-10-2016, 05:05 PM   #10
visceralsoup
This isnt even a map made for ethanol. Our cars should correct for small amounts. Heck, even california 91 is 10% ethanol.
Turbo Ranger Build
Old 03-10-2016, 08:33 PM   #11
Goingnowherefast
Goingnowherefast's Avatar
Drives: 16 GTI S 6MT, 91 Miata
Modern pump gas already has ethanol like mentioned so technically they already have a blend map and you are already using it lolol. Yeah as stated our cars correct for a small amount of ethanol, Id say up to E25 is fine. Can probably go higher but you just gotta log fuel trims when going higher etc.
2016 GTI S 6MT//2014 Fiesta ST 6MT//1991 Miata 5MT
Turbo miata build starting here: http://www.golfmk6.com/forums/showthread.php?t=96866
Goingnowherefast is offline   Reply With Quote
Old 03-10-2016, 09:00 PM   #12
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Back on the K04 I loved running E85 blends, night and day difference with how the car drove.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 03-10-2016, 09:21 PM   #13
visceralsoup
The difference is huge! The guy that dyno'd my car said that it actually ran with a better A/Fr when running the higher octane setting with the ethanol mix.
Turbo Ranger Build
Old 03-10-2016, 09:23 PM   #14
visceralsoup
Speaking of fuel trims, when using vcds, what blocks would I log to see long term and short term fuel trims? And what is a good target number?
Turbo Ranger Build
