Old 03-22-2016, 11:26 AM   #1
jackhossross
jackhossross's Avatar
Drives: VW Golf R '13 2D Rising Blue
Replacing Dogbone Mount, what else should I do during install
I am most likely going to order a dogbone mount - what else should i replace while under the car? Is this install straight forward?
Will be my first time working on the MKVI R, did plenty of bolt on work on my 2014 STI before this car.
Thank you,
Jack
jackhossross is offline   Reply With Quote
Old 03-22-2016, 12:05 PM   #2
visceralsoup
visceralsoup's Avatar
Drives: 2013 VW GTI (sold), 2012 Golf Arrrr
Whiteline anti lift kit
2 MOJITOS, STAT!- Thad Castle
Turbo Ranger Build
visceralsoup is offline   Reply With Quote
Old 03-22-2016, 03:45 PM   #3
nafljhy
Drives: 2011 UG GTI
are you talking about:
http://www.goapr.com/products/pendulum_mount.html
or
http://www.vibra-technics.com/vw/gol...me_mount_20r32
i see people call the subframe mount the dogbone mount sometimes.
if it's the former one, that actually looks like a dogbone, then the install is very straightforward. if you're doing the subframe one, you'll need to drop the subframe and can be a bit more complicated upon reinstall.
and i agree with visceral, go with the ALK either from whiteline or superpro.
Old 03-22-2016, 03:53 PM   #4
jackhossross
or
I don't know - just the dogbone insert?
https://www.ecstuning.com/ES6617/?gc...FQsPaQodvIAJEA
A lot of people have discussed this as an incredible inexpensive mod to do.
Old 03-22-2016, 04:07 PM   #5
nafljhy
Drives: 2011 UG GTI
got it! the insert! I've heard mixed reviews on the poly inserts. Things like it breaks down from wear and tear. if you don't mind a bit of nvh, I would say go for the 034 insert it atleast won't break apart when you decide to remove it.
https://store.034motorsport.com/bill...udi-tt-a3.html
Old 03-22-2016, 05:45 PM   #6
Optical TDI
Drives: GTI, S2000, Odyssey
Ditto on the 034 insert. Works great and super easy install.
Current: 2013 Odyssey / 2002 S2000 / 2014 Golf TDI
Previous: '13 GTI / '11 Cayman / '12 GTI / '10 Routan / '02 Targa / '07 RX8 / '06 GTI / '06 A3 / '03 WRX / '00 Golf TDI / '87 Wrangler / '87 RX7 Turbo / '84 RX7 GSL-SE / '82 RX7 / '78 280Z / '77 Buick Century
Optical TDI is offline   Reply With Quote
Old 03-23-2016, 12:05 AM   #7
jackhossross
Great, I'll do this and then hold off until stage 2 and clutch.
Also need to tackle the iPad install ...
