Old 04-23-2016, 03:50 PM   #43
lilonespaz
lilonespaz's Avatar
Originally Posted by aspirollari View Post
yea thats what i thought. What are the dangers of running stage 2 without their intake? Just a check engine light or something more serious?
Maybe some weird fuel trims. But most people that ive seen that are running stage 2 without cobbs intake arent having any issues.
Just the potential for your intake to not play nice..
Old 04-30-2016, 12:37 PM   #44
WalkerT
WalkerT's Avatar
I agree there are several people using aftermarket intakes. We would have to get some data logs from them to find out how the tune reacts to the smaller maf.
MK6 VW Driver's Group@Facebook 2012 GTI DSG Unitronics stg2, Billy boat 3" DP, IE intake, CTS 3" catback, D088 Intercooler, BFI stg1 engine mounts, O.Z. 18x8 Alleggerita, Charge pipe, up pipe, NS vent boost gauge, BFI DSG shifter, H&R sport, H&R adjustable rear sway 26mm, Koni orange, R8 coils
WalkerT is offline   Reply With Quote
Old 05-03-2016, 12:09 PM   #45
focusfuri75
How did you guys get CARB stickers for this intake?
It's NOT CARB certified, I just talked to someone at Cobb and they confirmed it.
They're gonna make a carb exempt intake later on, but not at this point in time.
Only way to be smog legal is to retain the stock MAF housing which the Cobb SF intake doesn't.
focusfuri75 is offline   Reply With Quote
Old 05-03-2016, 12:27 PM   #46
phuccer
Drives: 2012 GTI DSG 4DR CSG
I guess something happened with their certification. About 1-2 weeks ago, the question/answer section of the intake on COBB's website said it was recently CARB certified. Now it says it isn't.
phuccer is offline   Reply With Quote
Old 05-03-2016, 12:31 PM   #47
focusfuri75
Hmm, weird...
Old 05-03-2016, 04:38 PM   #48
MeanGreenGTI
MeanGreenGTI's Avatar
Drives: 2014 Black GTI Wolfsburg DSG
I'm running Cobb stage 2 OTS map with Uni intake and my car is running great. MAF readings are in the 210's. I haven't been able to data log too much because of shitty weather this Saturday is looking like the perfect day to data log and that is exactly what I will do. I'm cruising up to road of america so that a good amount of driving and gives me the ability to do some pulls and hold WOT. I'll be happy to share my logs once all said and done .
MeanGreenGTI is offline   Reply With Quote
Old 05-03-2016, 10:03 PM   #49
aspirollari
Originally Posted by WalkerT View Post
My APR intake max flow rate was 196 gs and this intake has already recorded 220 gs flow rate on MAF readings
im COBB stage 1 and my stage 1 evoMS intake reached 218 g/s. Is that a little odd? For a cheap stage 1 intake to have nearly as much flow as the COBB?
aspirollari is offline   Reply With Quote
Old 05-04-2016, 07:53 AM   #50
WalkerT
WalkerT's Avatar
That's not weird. Those are good numbers! It will all depend on your whole setup. Sense I have been running this setup for a couple of weeks. I have gotten 230-240. Depends a lot on outside temp and what the tune is requesting. I know that on my current setup I could not get the Carbino to flow more than 200g/s.
Old 05-04-2016, 08:15 AM   #51
lilonespaz
lilonespaz's Avatar
Just because its more expensive does not mean it will be better.
218 g/s is amazing. I think those guys with the IE intake were getting like 230 g/s and that thing has a 5" inlet with a velocity stack. IIRC
Old 05-04-2016, 10:29 AM   #52
JS12
I'm consistently getting around 206 g/s on my stock airbox and intake running the Stage 1 93 HB map. I have a COBB intake coming in today so I'm interested to see the difference with that and the Stage 1+ tune.
I also ordered a 3" airflow straightener from Treadstone just to experiment with.
JS12 is offline   Reply With Quote
Old 05-04-2016, 10:56 AM   #53
WalkerT
WalkerT's Avatar
Let me know how the straightener works out. I know Ryan was testing one on his new setup
Old 05-04-2016, 11:16 AM   #54
JS12
Will do!
Old 05-07-2016, 09:00 PM   #55
JS12
I got the COBB intake installed but haven't had a chance to test out the straightener since my fuel trims seem way too high after switching to the Stage 1+ tune. I've tried adjusting and re-tightening everything a few times but LTFT idles around 1.04-1.05 and gets up to 1.15 while cruising. I'm not seeing any knock or other issues.
Has anyone had a similar experience? Any pointers on troubleshooting steps or is this normal until adaptation is done? I might have 40 miles on the current map. Fuel trims were a stable 1.00 with the stock airbox.
Old 05-07-2016, 10:07 PM   #56
spegheddy
Drives: 2012 GTI 4 Dr DSG
Positive fuel trims generally indicate a leak pre-turbo. For instance you have some air leaking into your intake that's not accounted for by the MAF, The result is high fuel trims as your ECU needs to add more fuel to compensate for that leak.
I would double and triple check your hose connections pre-turbo as that'd be the most likely culprit IMO.
2012 CSG GTI, 4 Dr, DSG. Cobb pro-tuned through Stratified. Neuspeed Pflo, Neuspeed catback, GFB DV+, R8 coilpacks
spegheddy is offline   Reply With Quote
