Old 05-01-2016, 01:44 PM   #1
Lowpez22
Lowpez22's Avatar
Drives: 2011 gti 2.0l tsi
Water pump
One failed Mofo!
Gti MK6 ccta 2.0t
I see there are many topics on the water pump issue. And so called recall I've called very dealer in a 100mi radius and not hitching the can see. Also called VW and also they don't see a recall on this. If anyone has any help on this pleas help a vw brotha out. At this point I have taken it out and found the issue.
Well any help would be awesome
iPhone
Lowpez22 is offline   Reply With Quote
Old 05-01-2016, 02:01 PM   #2
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
Is it a recall, or a warranty extension they did on this...?
Or neither?
Old 05-01-2016, 02:03 PM   #3
Lowpez22
Lowpez22's Avatar
For what I have found
It's a recall on it but no one seem to have it in thier system
iPhone
Old 05-01-2016, 02:45 PM   #4
11gti718
I have a 2011 gti cbfa. Dealer replaced it under a recall. My waterpump didnt fail or anything. They just replaced it under the recall. You can check here and type your vin. Hopefully it helps.
http://www.vw.com/owners-recalls/
Old 05-01-2016, 02:46 PM   #5
Lowpez22
Lowpez22's Avatar
I already checked there and called the customer support
iPhone
Old 05-01-2016, 04:20 PM   #6
Pooley
Drives: 2011 CW GTI Autobahn
I live in PA which sold CBFA cars, but my car originated in MD which sold CCTA. Have a friend that works as a service advisor at local VW dealer. Last year I mentioned the water pump issue and he checked the system and it seems only CBFA are listed under the extension since mine wasn't showing in the system when he checked.
Sent from my SM-G920V using Tapatalk
2011 CW GTI 4 door DSG
GIAC K04/ AWE CCB/ AWE TOP/ AWE Downpipe/ AWE Exhaust/ AWE Boost Gauge/ Deadset/
Neuspeed FMIC/Eibach Coilovers/ H&R 24mm Rear Bar/ Rotiform SPF wheels/ Unibrace XB and UB / Super Pro ALK
Pooley is offline   Reply With Quote
Old 05-01-2016, 04:28 PM   #7
Lowpez22
Lowpez22's Avatar
iPhone
Old 05-01-2016, 07:17 PM   #8
bigturbonyc
Drives: mkv gti
Your cylinder head cover is leaking oil down to the wp causing that seal to swell and break...fix that asap or you'll be doing another wp soon.
bigturbonyc is offline   Reply With Quote
Old 05-01-2016, 07:18 PM   #9
Lowpez22
Lowpez22's Avatar
What? Cylinder head
iPhone
Old 05-01-2016, 07:19 PM   #10
Lowpez22
Lowpez22's Avatar
That oil was from a leaking cam shaft postion sensor I fixed a while ago
iPhone
Old 05-01-2016, 07:40 PM   #11
bigturbonyc
Drives: mkv gti
As long as no oil is coming from the top.
There is no valve cover on this engine, it's called a cylinder head cover. And they leak, the red anaerobic sealant they use from the factory doesn't last long.
Old 05-01-2016, 07:42 PM   #12
Lowpez22
Lowpez22's Avatar
Thanks I'm waiting on my pump and I'll inspect and shoot you some pictures and see if you can tell if it is
iPhone
Old 05-03-2016, 01:52 PM   #13
Lowpez22
Lowpez22's Avatar
Let me know what they say and where I can get that info
iPhone
Old 05-03-2016, 02:02 PM   #14
You made it that far, a new pump is like $300.
