Old 05-02-2016, 11:21 PM   #1
proofofpayment
Drives: '11 CSG 2dr GTI DSG
Help! Car jerks + power cuts occassionally
Hey,
So in my 2011 GTI with 80k kms, I've been noticing some odd behavior recently. Yesterday, while at a stoplight, the car refused to go upon pressing the gas for about 1s, there was no revving, nothing. Then it kicked into gear and went. Today, in first gear, the power cut temporarily (rev, then suddenly stopped revving) under normal acceleration (i.e. not flooring it), and this jerked the car back in the process slightly. About 0.5s.
I've noticed similar issues before, though not as frequently, about a year ago since going stage 1. I have replaced my coilpacks and sparkplugs recently, VAGCOM logs some misfires on startup and some while driving on occassion, no CEL, and I don't feel them.
Since going stage 1 REVO, I've also had the issue of jerky upshifts, as in the car lurches back like a single clutch when upshifting under load at low rpms. This is sporadic, and I'm not sure if it's related.
Any help would be appreciated
Thanks
'11 CSG Autobahn: REVO Stage 1, Niche Targa 18" Anthracite, Magnaflow Catback, Solowerks S1 Coilovers, Dark Cherry LED Tails, Ghetto LED license plate, Ghetto red footwell lights, VAGcom, CSG side markers etc.
Follow me on Instagram: @will.mk6gti
proofofpayment is offline   Reply With Quote
Old 05-03-2016, 09:12 AM   #2
lilonespaz
lilonespaz's Avatar
Do you have the ability to switch to "Stock" mode to see if it still happens?
Check that the plugs are gapped correctly.
Old 05-03-2016, 09:18 AM   #3
charrigan
Drives: 2013 GLI
plugs and coilpacks would be the first check/replacement. Likely you have a coilpack beginning to fail
2013 FIAT 500e
2013 GLI
2013 Audi Q5 2.0T
charrigan is offline   Reply With Quote
Old 05-03-2016, 01:51 PM   #4
proofofpayment
Forgot to mention but i had the plugs and coilpacks replaced 10k ago to fix some misfiring
Old 05-03-2016, 01:52 PM   #5
proofofpayment
Switching back to stock makes it slightly better . upshifts not jerky but similar problems on occasion.
Old 05-03-2016, 01:55 PM   #6
lilonespaz
lilonespaz's Avatar
Have you checked your engine mounts? does it feel like a broken mount possibly?
Old 05-03-2016, 02:21 PM   #7
proofofpayment
Very possible. My front end is a bit misaligned (hood not center even though it is, so something to do with fender. I'm not sure how but I was once told this could be engine mount related. What would the effects be I suppose I'll get a shop to check it. How much do those go to replace?
Old 05-03-2016, 02:26 PM   #8
dAT_Sloth
dAT_Sloth's Avatar
Drives: 2011 CSG 4dr DSG
Very possible. How much do those go to replace?
I have the same year and trans as you, I went stage 2 on factory mounts, and they didn't last long. Even on a mild tune the fluid filled factory mounts are inadequate.
As for pricing, I think they're about $150 or less per mount (only 2) and the dogbone is cheaper than that. I'd check your subframe hockey puck first though, it'l be the most expensive one to replace because you have to drop the subframe but it will save you the hassle of replacing mounts and not fixing the problem.
APR Stage 2 v2.1 / APR DSG v1.6 / BB 3" Catless DP / AWE 2.5" CB / GFB DV+ / Forge WINtake / ECS Poly Engine & Trans Mounts / Hawk HP+ & HPS/ ECS SS brake lines / Motul RBF 600 / ECS Geomet d&s rotors / ECS Performance Caliper Guide Bushings / ECS Angled Vent Pod Boost Gauge / R8 coil packs / Alzor 18x8 349 / Conti DW
dAT_Sloth is offline   Reply With Quote
Old 05-03-2016, 02:33 PM   #9
bart2278
bart2278's Avatar
There are a bunch of car jerks on this forum. Just get use to it.
Old 05-03-2016, 02:50 PM   #10
proofofpayment
Wonder if warranty would cover the engine mount.
Old 05-03-2016, 02:53 PM   #11
bryngutierrez46
Carbon cleaning might be too my car had misfires on cold start ups and no more since i got it done
bryngutierrez46 is offline   Reply With Quote
Old 05-03-2016, 03:20 PM   #12
dAT_Sloth
dAT_Sloth's Avatar
doubtful, wearable part.
Old 05-03-2016, 03:21 PM   #13
dAT_Sloth
dAT_Sloth's Avatar
Mine does this too ever since the new APR update, but when the car is warm it runs great. Had the car carb cleaned last summer, only done about 15k miles since then.
Old 05-03-2016, 03:57 PM   #14
charrigan
Drives: 2013 GLI
oem coils or r8?
I would still check them... hearing of failed coilpacks at 10k isn't unheard of.
2013 FIAT 500e
2013 GLI
2013 Audi Q5 2.0T
