Old 05-03-2016, 10:18 AM   #1
Mk6 Steve
Drives: 2013 Black GTI coupe DSG
What are my TOP options if staying with oem hoses?
I just installed a golf r intercooler and reused the oem hoses with the metal ends cut off. Now that most of my hoses are fastened securely with worm gear clamps that leaves that shit plastic pancake pipe and the original clip type connector as a source of constriction and boost leaks. What are my TOP options that will play well with oem hoses without the metal connectors?
APR Stg 2 V2.4 w/ EMCS, Carbonio Stg 1 + 2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit, AWE S3 top, Neuspeed charge pipe, GFB DV+ New revision, Rev D, R8 coils w/ NGK 2667, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is online now   Reply With Quote
Old 05-03-2016, 10:54 AM   #2
Wasn't there was just a thread on this? I think the Audi TT pipe or maybe AWE but why limit yourself to stock hoses when you're upgrading everything else?
Old 05-03-2016, 11:01 AM   #3
GunKata
MILFn00dzHunter.com
GunKata's Avatar
AWE S3 TOP FTMFW.
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
Old 05-03-2016, 11:14 AM   #4
Mk6 Steve
Isn't the TT pipe also pancake shaped with the exception of the clip type connector? Aftermarket hoses are too expensive for the gains I would get from it. Plus I'm not going K04.
Old 05-03-2016, 11:19 AM   #5
GunKata
MILFn00dzHunter.com
GunKata's Avatar
dunno on the TT. All i know is, for reliability and not having to worry about it, its a great mod, not sure I had any idea on gains for it, that wasn't really why I had run it. Boost leaks just suck.
Chicago Car Network
Old 05-03-2016, 11:19 AM   #6
Mk6 Steve
Will the S3 TOP from AWE work with the oem hose fastened by a worm gear clamp?
Old 05-03-2016, 11:22 AM   #7
Mk6 Steve
I hear you, but if I could kill 2 birds with one stone and improve reliability and efficiency...
Old 05-03-2016, 11:31 AM   #8
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
AWE S3 TOP FTMFW.
This /thread
CLICK HERE FOR MY BUILD
Old 05-03-2016, 12:23 PM   #9
Nineeightgolf
Drives: 2011 gti
If you buy the spulen kit, because its a great price for both pipes, do not try and use the included coupler that hooks up to the turbo outlet. It fits like crap. Save yourself the trouble and use the OEM coupler. No experience with the AWE.
Nineeightgolf is offline   Reply With Quote
Old 05-06-2016, 02:43 AM   #10
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Yes, similar to the stock pipe but gets rid of the clip connection though
If you want to use the OEM hose & cut the metal ring off, I don't think so. The Neuspeed TT version (no longer available) was 57mm and people said it was a tight fit with the OEM hose.
The AWE is bigger, 63mm (at the end) and might be too big for the OEM hose to slide over....it's for aftermarket hoses.
If someone has used it with the OEM hose though...please feel free to correct me/chime in because I'm curious too
2017 Passat VR6
2017 Passat R-line
Old 05-06-2016, 02:55 AM   #11
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Originally Posted by Cadubya View Post
This /thread
Does it work with the OEM hose though?
(metal ring trimmed off, of course)
2017 Passat VR6
2017 Passat R-line
Old 05-07-2016, 01:56 AM   #12
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
2017 Passat VR6
2017 Passat R-line
Old 05-07-2016, 07:25 AM   #13
blue_mkvi_gti
blue_mkvi_gti's Avatar
Drives: 2012 SB MK6 GTI Eurodyne Stage 2
http://www.golfmk6.com/forums/showthread.php?t=104607
Eurodyne ECU+DSG Stage 2 GolfMK6 abomination: 2010_carbon_gti's H&R rsb, ///Audience's 034 street density motor and transmission mounts, naDintheHat's Autotech dogbone insert, Muratti's SPM fsb, tjbell's SPM catback, wwgti2.0t's GFB DV+, TheJakofallTrads' Team Dynamics wheels, DSR7's winter wheels/tires, someone's Carbonio and Eurojet DP; and my Powergrid end links, Deautokey LED everything, Neuspeed TOP & TBP, and Whiteline ALK.
blue_mkvi_gti is offline   Reply With Quote
Old 05-10-2016, 02:09 AM   #14
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Originally Posted by blue_mkvi_gti View Post
LOL, you redirected me to my own thread
Oh well, I guess no one has done it. I'm gonna order the AWE pipe and see if it'll work
Worst case, maybe hack off the flared part at the end
We'll see. . .
2017 Passat VR6
2017 Passat R-line
