Old 05-10-2016, 04:06 PM   #1
Jamester
Drives: 2011 vw gti mk6
Getting misfires and ruff idle... CEL & EPC lights on
Hoping to get suggestions on my problem. For the past month when I first start the car up in the morning it will be misfiring with the CEL blinking. I'll drive it like this for about 2 miles shut the car off for about 20 minutes. After I let it sit I restart the car and all seems normal (CEL still on) like there's nothing wrong. The CEL test reads Multiple misfires in a given period of time. I've checked the fuel, disconnected battary for 2 hours to reset computer, new plugs and coils with no discoloration or residue, unplugged maf no change and looks clean. Checked fuses all good. No idea what to do next I like to fix my own vehicles and trying to avoid paying a shop. Only thing I can think of is a bad tune (stage 2) but it's been fine for the 6 months I've had it. Any suggestions?
Unitronic stage 2 - Eurojet TBE - Neuspeed intake - Neuspeed FMIC - Neuspeed turbo pipe kit in/out - Forge DV spacer - New South boost gauge
Jamester is offline   Reply With Quote
Old 05-10-2016, 04:08 PM   #2
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
My guess is plugs or coils, and you should stop driving it with a blinking CEL.
Old 05-10-2016, 04:10 PM   #3
luvdagators
luvdagators's Avatar
Drives: 13 CW Autobahn GTI (o\!/o)
Location: Corner of grey street and the end of the world NC
x2
luvdagators is offline   Reply With Quote
Old 05-10-2016, 04:23 PM   #4
Jamester
Plugs and coils are brand new and still look new when I inspected them. And this only happends when I first start it up in the morning then it's fine the rest of the day.
Old 05-10-2016, 04:35 PM   #5
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Blinking CEL + EPC + misfires is almost always a coil or a spark plug. I can't think of what else it might be, but maybe someone more knowledgeable has a better idea. You might get some better answers if you get it scanned too.
Old 05-10-2016, 05:16 PM   #6
corydd
corydd's Avatar
Drives: '10 CW GTI DSG Autobahn
Could be an injector... but most likely a spark plug or coil pack. Have you checked error codes to see which cylinders are misfiring? I would try getting some R8 coilpacks. They usually fix the problem.
'10 CW DSG GTI Build Thread & Flickr * APR Stg 1 * Depo Tails * Magnaflow CBE * OEM Lip * VW Motorsports Wheels * VWR Springs * Stoptech Pads * DeAutokey LED's * 24mm H&R RSB
corydd is offline   Reply With Quote
Old 05-10-2016, 05:17 PM   #7
Jamester
Just got the CEL scan.
-P0100 mass or volume air flow A circuit
-P0304 Cylinder 4 misfire detected
Old 05-10-2016, 05:19 PM   #8
Jamester
I have the R8 coils packs on already and autolite platinum plugs about 3 months old.
Old 05-10-2016, 05:47 PM   #9
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
It sounds like p0100 could be a faulty MAF? I tried finding some results on google, but didn't really come up with anything other than the MAF. You could try a MAF cleaner. I'm not sure if that'll help or not though, I couldn't find a lot of info on that code.
I've experienced a bad MAF in my last car, but it's like you described. It would misfire and it had a really rough idle, I think I probably even stalled it a few times. When I unplugged it the car actually ran better, and I drove like that for a day or 2 until I got a new one, but you said you tried that and it didn't change anything...
Idk man, that's as much as I can help lol
Old 05-10-2016, 05:59 PM   #10
Drives: 10 GTI CSG DSG K04 4DR 130k+
Sounds like maybe the wire harness for the MAF? Autolite plugs wouldn't be my first pick, but have you ever had the intake manifold replaced or a carbon clean?
Old 05-10-2016, 06:14 PM   #11
Jamester
Nope no carbon clean and stock intake manifold. I'm at about 63000 miles and I know I'm going to need to do that soon.
Old 05-10-2016, 06:28 PM   #12
Jamester
Could I be throwing a maf code cause I disconnected it when I was testing?
Old 05-10-2016, 06:37 PM   #13
AGEE4
AGEE4's Avatar
Intake valves might need a walnut blast?
AGEE4 is offline   Reply With Quote
Old 05-10-2016, 09:23 PM   #14
pamatt
Drives: Mk6 2012
I had the same problem. It was my intake manifold.
Vf mounts, Sb stage3 daily, Peloquin diff, I.E. intake manifold, St coilovers, Milltek cb, APR-intake, dp, ic, UM software.
pamatt is offline   Reply With Quote
