Old 08-31-2016, 05:27 AM   #1
PNW_GABE
PNW_GABE's Avatar
Drives: 2012 Candy White GTI
Angry Clunking noise after coilover install.
Installed solo werk s1 coilovers on my mk6 couple days ago. Ever since it was made this clunking noise over big bump I hit. I've installed coilovers on many cars but the mk6 has definitely been the most difficult. Seemingly did everything right not sure what is making the noise. Any help? Thanks
Video of noise: https://youtube.com/watch?v=iXMhZkPNqbkat
PNW_GABE is offline   Reply With Quote
Old 08-31-2016, 07:22 AM   #2
TimS
Drives: '12 Golf R
Assuming the bolts are properly torqued, either the mount is bad or you forgot to reinstall the bearing.
Old 08-31-2016, 02:26 PM   #3
PNW_GABE
PNW_GABE's Avatar
Hm. Nope brand new top mounts and bearings.
Old 08-31-2016, 03:51 PM   #4
lleron
Drives: 2012 2dr 6spd White GTI
Subframe shifting or something hitting? Mine still makes noise and can be felt in the steering wheel when I hit a big bump but I'm pretty sure it's my swaybar hitting something.
Do you have adjustable endlinks?
lleron is offline   Reply With Quote
Old 08-31-2016, 10:19 PM   #5
Blaznjoe
Blaznjoe's Avatar
Drives: 2012 MK6 GTI 2-D CSG
Per the video, either your top strut nut isn't tightened all the way or the three bolts that hold the strut mount to the chassis are not tightened properly.
2012 MK6 GTI 2-D CSG 6SP-MT
GIAC Stage 2e40|SPM Street DP|SACHS Performance Coilovers|VOLK ZE40's|Neuspeed BBK,Pulley,P-Flo,TOP,FMIC,CBE,SS brakelines,& ShortShifter|Whiteline ALK|Hotchkis F & R Swaybars|Autotech Rotors|Hawk Pads|EuroSport X-Brace|TyrolSport DS SF C Kits|GFB DV+|SB.S2.SMFW|Wavetrac|Michelin PSS|Podi|ECS CatchCan www.kopropo.com/america/
Blaznjoe is offline   Reply With Quote
Old 09-01-2016, 07:03 AM   #6
TimS
Drives: '12 Golf R
Then you need to tighten down the top nut on the strut all the way, since the mount bolts don't appear to be moving.
Old 09-02-2016, 04:13 AM   #7
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Which mounts? The (recommended for the SoloWerks) stiffer 034 Motorsport ones?
Looks like the mount is flexing (really bad) or the strut rod nut isn't tightened all the way down.
Use a allen wrench/hex bit to hold the rod and a wrench to tighten the nut down
2017 Passat VR6
2017 Passat R-line
Old 09-03-2016, 05:10 PM   #8
Tjbgtv8
Tjbgtv8's Avatar
Drives: 2010 VW Gti 6spd
Tighten that nut down and you should be fine.
Tjbgtv8 is offline   Reply With Quote
Old 09-04-2016, 11:11 AM   #9
Bowthewow
Bowthewow's Avatar
Drives: Slow MK6 GTI
Had the same issue after installing bags, ended up the rear strut mount was loose and was making clunks on every bump. Now trying to find where a squeak is coming from. Seems like it is cause by the foam around the spare tire making friction.
Tuck them like
Bowthewow is offline   Reply With Quote
Old 11-25-2017, 12:24 AM   #10
PNW_GABE
PNW_GABE's Avatar
Way late reply but ended up being two blown struts right out of the box. Not impressed with solo werks
Old 11-26-2017, 03:16 PM   #11
Cal2000
Drives: 13' GTI 4DR AUTOBAHN
Ouch. Are they giving you new ones though?
Old 11-26-2017, 10:43 PM   #12
nvturbo
nvturbo's Avatar
I used to have SW as well. Warranty was just about over and I had to get 2 rear struts. Unfortunately, I had to pay for shipping (of the replacements). For low budget coilovers, I would suggest WRD's instead. That's what I switched to.
Old 11-27-2017, 04:35 AM   #13
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
They used to all be the same, except rebadged & painted a different color with different warranties
WRD, SoloWerks, & Pwrhaus (BFI's version)....based on (if not the same as) the old FK Streetline design
Since then though...the FK Streetlines & SoloWerks switched to a ST (looking) style coilover setup
Old thread:
http://www.golfmk6.com/forums/showthread.php?t=98740
2017 Passat VR6
2017 Passat R-line
coilovers, noise, solowerk, weird
