Old 09-18-2016, 04:46 PM   #1
#madrussian
Drives: 2013 Golf R 4 Door
Weird Noise Knock from Tranny
Hey all,
Was driving last night and noticed a weird situation with the car.
At above 3.5K rpm if I drop the throttle then get back on it there is a very noticeable knock like a catch up of the engine to the transmission or something. Feels quite unsettling, almost like a clutch drop.
Really only happens in 3rd and above gears, in 1st and second its like the engine and tranny are glued, the flow of rpm up and down is very consistent without breaks.
Has anyone has something similar occur? Is it time for a new clutch? Or something worse?
Any info would be appreciated.
Thanks.
#madrussian
#madrussian is offline   Reply With Quote
Old 09-18-2016, 06:31 PM   #2
Clutch slip? Are you tuned?
Old 09-18-2016, 07:36 PM   #3
#madrussian
It doesn't slip as far as I can tell. No chips no tunes. Only performance 'mod' is a k&n air filter.
Old 11-25-2016, 01:57 PM   #4
visceralsoup
visceralsoup's Avatar
Drives: 2013 VW GTI (sold), 2012 Golf Arrrr
My car has this issue too. Its like something in the drive line is shifting. I have upgrade mounts though so I dont think it is the engine or tranny. My thoughts are maybe the rear differential
2 MOJITOS, STAT!- Thad Castle
Turbo Ranger Build
visceralsoup is offline   Reply With Quote
Old 11-25-2016, 07:57 PM   #5
I believe it's the differential wearing out. Good excuse for LSD upgrade.
Old 11-25-2016, 09:00 PM   #6
brobst
brobst's Avatar
Drives: CSG mk6 6MT
At a stock level, you think its just the engine moving around? That thing flexes alot
Sent from phone Tapa
Old 11-25-2016, 11:03 PM   #7
visceralsoup
Front diff? Or rear?
Turbo Ranger Build
Old 11-26-2016, 06:13 AM   #8
iGTI
iGTI's Avatar
Most likely the rear... check for leaks not sure how many miles you got but thats not an area you want to neglect.
S3 16'
STG 1+ Sold
Old 11-26-2016, 03:37 PM   #9
visceralsoup
Ive inspected it and there are no leaks. I think I will do a fluid change soon. I know a guy selling a warrantied diff so I might get it just in case
Turbo Ranger Build
Old 11-30-2016, 12:48 PM   #10
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
Could it be your DMF is starting to go?
Old 12-02-2016, 04:42 PM   #11
bebersol
bebersol's Avatar
DMF?
Bunch O'Stuff :-)
Old 12-02-2016, 04:43 PM   #12
bebersol
bebersol's Avatar
is that the rubber bushing where the drive shaft connects to the transmission and rear diff?
I think it's called a Rear Harmonic Balancer.
Bunch O'Stuff :-)
Old 12-02-2016, 06:16 PM   #13
bebersol
bebersol's Avatar
ECS has a replacement for about $150, it's exactly the same as the $460 OEM part because FEBI manufactures the part for VW
Bunch O'Stuff :-)
Old 12-02-2016, 06:55 PM   #14
visceralsoup
Originally Posted by bebersol View Post
DMF?
Dual mass Flywheel I believe
Turbo Ranger Build
