Old 09-19-2016, 06:45 AM   #1
NerminGTI
Drives: gti
Mk6 GTI losing Power
Hi guys I need help
I have mk6 gti eurodyne stage2
I just change new sparkplug and new Ignition Coil and dv valve
and I'm still losing power after 3rpms
Dose anyone have this problem
NerminGTI is offline   Reply With Quote
Old 09-19-2016, 10:41 AM   #2
xing
Drives: MK6 GTI
Check for boost leaks?
Sparks torqued down correctly? (30nm)
Everything plugged in?
Fuel injectors?
Any engine codes?
Does the engine shake more than usual at idle? Weird idle revs?
Did you change the spark plugs, ignition coils and DV in order to fix the problem or did this problem arise after you changed these items?
Triple check the coils. It isn't out of the ordinary to get a bad coil from the retailer.
What spark plugs did you install?
xing is offline   Reply With Quote
Old 09-19-2016, 01:28 PM   #3
matty mk6
Drives: 2010 DSG
i would check for boost leaks. i just had one myself. oil was coming out of turbo outlet leaking down the pipe. i tightened up a few clamps and the power came back
APR K04 / CTS TBE / CTS FMIC / CTS TOP / CTS TB / RocEuro CAI / R8 Coilpacks
matty mk6 is offline   Reply With Quote
Old 09-19-2016, 09:55 PM   #4
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Scan it and see if you have any codes
Old 09-20-2016, 12:14 PM   #5
jettaglis
jettaglis's Avatar
this
Uni stage 3....gt3076
Instagram: vsc_tuning
