Old 11-16-2016, 12:20 PM   #43
davserbic
davserbic's Avatar
Drives: Golf MKVI
Originally Posted by Hlocke480 View Post
glad to see the 2.5 group back up. this section has been dead for a minute
Haha, its starting to build up again but we still need mad inspiration! Start posting pics!
Golf 2.5L Build Thread | Airlift Slam Series + V2 Management | APR Carbonio | Mercedes Alphards | Golf R Conversion |
FOLLOW ME ON IG: @DAVSERBIC
davserbic is offline   Reply With Quote
Old 11-17-2016, 11:56 AM   #44
jay745
jay745's Avatar
I have the day off so I'm going to install this bfi stage 1 trans mount bushing. Will let you guys know how it goes!
Old 11-17-2016, 01:26 PM   #45
MLue1
What advantage does this give?
Old 11-17-2016, 03:14 PM   #46
jay745
jay745's Avatar
It stops the transmission from rocking back and forth during shifts leading to a sloppy feel and the feeling of the engine/trans about to fall out when you shift. The oem bushing is made of rubber, and has holes drilled in it to absorb the vibrations for comfort. The rubber gets worn out over time and leads to a very sloppy feeling. I could put my hands on the engine in the bay and literally rock it back and forth. Now it's completely solid.
The install was easy. Jack the car up on stands, support the trans with a jack from the bottom, remove the battery and tray, lift the wiring harness up and move it out of the way, remove the 6 bolts holding the mount in place...
Then you have to drill out the rivets holding the mount together - sounds bad but its really easy. You remove the oem bushing and replace it with the new poly bushing. I went with the BFI stage 1 bushing. Re install everything in reverse order.
The car drives so much better now and has a solid feeling during shifts. This will help with reducing wheel hop as well. For the price, you can't beat this mod. Pair it with an engine mount and it's even better.
Oem on the left, bfi on the right.
Mount removed and rivets drilled
After the rivets came off
Old 11-17-2016, 08:01 PM   #47
MLue1
Thanks Jay, you're wealth of information. I rocked my engine fore/aft, seems solid enough for now. I'll keep an eye on it.
Old 11-18-2016, 05:36 AM   #48
eyedeas
eyedeas's Avatar
Drives: '11 Golf 2.5 5spd
It wasnt today but I have installed the Black Forest Industries Stage 1 Engine, Transmission, and Dogbone mounts in my 2011 Golf and DAMN does it feel good!!! A little bit of vibration has been added but since driving it/breaking them in it has decreased notably but its still there...however its like a small back massage lol
eyedeas is offline   Reply With Quote
Old 11-18-2016, 11:24 PM   #49
donutpop365
Drives: 2013 Volkswagen Golf 2.5L
Talking
Today we got our first snow here in Minnesota and Aubrey got her new winter shoes installed. They're General Altimax Arctics and wow do they work great! Drove the Honda CR-V with all seasons and my car with the Generals back to back and the difference is incredible. Stopping and turning are a breeze in my car versus just plowing straight forward with either braking or turning in the CR-V.
Have a couple other things I did a while back I ought to post here!
Now just have to do the ESC defeat so I can do some donuts
donutpop365 is offline   Reply With Quote
Old 11-19-2016, 01:25 PM   #50
Muratti
Muratti's Avatar
Drives: 2012 UGM GTI-DSG
Started to perform 80k maint.. Changed the spark plugs. DSG fluid and fuel filter next.
Sent from my SAMSUNG-SM-G935A using Tapatalk
35 Prct Tinted|OEM Interior LEDs|Koni Oranges|DG Springs|Euro Switch|Black Side Markers|PIAA Plasma Ion Fogs|R8 Coils|NGK PFR7SEG Spark Plugs|Neuspeed RSe12 with Conti DWS06|Neuspeed P-Flow Intake|DEPO Headlights with Morimoto HID 4500 Kit|
Muratti is offline   Reply With Quote
Old 11-19-2016, 01:26 PM   #51
donutpop365
I have to do spark plugs soon, how is it on our cars?
Old 11-19-2016, 01:37 PM   #52
jay745
jay745's Avatar
About as easy as it can get. Just be careful and take your time removing the wiring harness from the coils. That plastic is fragile.
Old 11-19-2016, 09:36 PM   #53
MLue1
After several years Ifinally figured out how to remove the connectors from the coil packs without using a screw driver to pry at it. I now start the car if the engineis stone cold. You have to push the connector in like you pluging in then squeeze the little handle down then pull back. Once you get it , it's as easy as pie.
Old 11-20-2016, 11:12 AM   #54
Yayotas
Yayotas's Avatar
Drives: Mk6 golf 2.5l
I just got mine tuned yesterday. I went with the UM tune. So far I love it.
Instagram: @Yayotas | Golf 2.5L, ST coils, One perfect Dose LED tails, DeAutoKey LED interior and License Plate, Custom Exhaust, Brada Wheels BR-10 | DUUUUUUUUVAL Go Jags!
Yayotas is offline   Reply With Quote
Old 11-20-2016, 11:21 PM   #55
donutpop365
I've been thinking of doing this but it's kinda pricey 🙁
Old 11-24-2016, 10:04 AM   #56
Yayotas
Yayotas's Avatar
I got it done during fixxfest so there was a little bit of a discount.
