Old 12-01-2016, 05:29 PM   #57
somerset9
somerset9's Avatar
Drives: 2014 GTI 6MT Wolfsburg Edition
Originally Posted by Yayotas View Post
I got it done during fixxfest so there was a little bit of a discount.
Nice! I'm a little on the fence about this one. I don't want to mess with the warranty I have but I'll be damned if the 2.5l can't use a little more pep in it
somerset9 is offline   Reply With Quote
Old 12-03-2016, 04:39 AM   #58
donutpop365
Drives: 2013 Volkswagen Golf 2.5L
Changed my spark plugs today and replaced the cabin filter. Also fixed an annoying rattle the climate control fan was making.
I used Bosch Plugs off Amazon and the Mann filter.
Everything went well except due to the Minnesota cold the engine cover was brittle and the rubber grommets holding it on were very stiff. As a result of this when I went to pull it up a corner piece snapped off .
Drove around a bit getting everything toasty and the cover came off as easy as pie, wish I had thought of the cold earlier. I waited a couple hours to do the plugs to let the engine cool.
The cabin filter was absolutely disgusting. I also took out the passenger side fan and removed a couple of leaves that somehow got in and were making noises.
Anyways, where is the best place to get a new engine cover?
I was thinking eBay or junkyards if I wanna go with the original. Otherwise if I splurge I could pick up an intake and swap for a beetle engine cover.
Thoughts?
donutpop365 is offline   Reply With Quote
Old 12-03-2016, 05:15 AM   #59
somerset9
somerset9's Avatar
I'd recommend the USP or BSH cold air intakes, as the APR carbonios are harder to find than Carmen Sandiego.
The beetle covers are pretty common on craigslist/junkyards
Old 12-03-2016, 05:47 AM   #60
donutpop365
Those both look really nice, especially since the APR was discontinued. I'm torn between this style and something like the Neuspeed P-Flo. I bet the true cold air intake style is more effective but I also worry that not only would the filter get filthy very quickly but also worry about the effects of snow and mildly deep water.
Old 12-04-2016, 10:40 PM   #61
somerset9
somerset9's Avatar
That's true, I live in southern California (for now), so not much precipitation to account for.
I got my Eurojet exhaust installed today! Noticeable drone on the highway when I'm giving the engine a bit more gas to go 70+ MPH or uphill, but nothing a little music can't fix. On local roads, I love the deep growl the engine has now
Old 02-05-2017, 03:56 AM   #62
MLue1
Lightbulb
Got back from the Rolex 24 hour race in Daytona a few days ago go me thinking about installing a short runner intake system on my 2.5. I removed the stock intake to take some measurements I may try to build one myself.
Old 02-06-2017, 01:54 AM   #63
eyedeas
eyedeas's Avatar
Drives: '11 Golf 2.5 5spd
Good luck to you! I hope you have done some research. Integrated Engineering has an amazing SRI that you should check out.
eyedeas is offline   Reply With Quote
Old 02-06-2017, 01:18 PM   #64
madbikes
Drives: 2012 Golf 2.5L 5-speed
I re-installed the rear sway bar as the bushing backed away from the mounting hardware. Should be plenty tight now.
APR-Carbonio intake/United Motorsports Tuned/Black Forest Industries 2.5L Lightweight Flywheel and Clutch kit/Black Forest Industries Stage 1 Motor mount+transmission mount+dogbone insert/Bilstein PSS coilovers/034 Motorsport Rear Sway Bar/StopTech ST-40 328mm Big Brake Kit/StopTech stainless steel brake lines
madbikes is offline   Reply With Quote
Old 02-06-2017, 10:38 PM   #65
MLue1
Lightbulb
Thanks I like to tinker with stuff, for whatever its worth. I know about the IE SRI and tune, being around performance cars and racing a long time, but I can't say I'm very impressed enough to pay over $2000 CAD$ for their stage 2 SRI and tune. The IE SRI manifold does produce good HP high up in the rev range but not enough midrange torque to even make it competitive with a stock GTI.
To start the project, I ordered an intake manifold from a dismantler today, I will cut it up and see what I can make. I like the power curve of the IE Stage 1 tune, (205 TQ), which I can get from United Motorsport (UM), so I plan to make my version of SRI that will extend the HP peak a bit longer.
EDIT: getting alot of info from this old Vortex Thread
http://forums.vwvortex.com/showthrea...ld-info-by-NLS
Old 02-06-2017, 11:02 PM   #66
MLue1
I torqued my Hotchkis hardware to 35 ft-lb
Old 02-09-2017, 10:47 PM   #67
MLue1
Smile
Stopped by Definitive Tuning today, to do a baseline dyno pull to compare with future results. Best price and support for Dyno pulls around the Toronto area.
Only mods installed P-Flow Intake and axleback GTI Suitcase Muffler (original Mid Muffler).
WTQ - 170 ft-lb
WHP - 153 HP
EDIT: Someone contacted me regarding my stock numbers and graph in comparison to the stock ones posted on the Integrated Engineering (IE) site. All I can say is that my baseline was done on a Dynopack Dyno like IE used and are the HP and Torque are the driving wheels for my car. I can't speak for the numbers on the IE web site.
Old 02-10-2017, 11:48 AM   #68
FlowMK6
FlowMK6's Avatar
Drives: Golf 2.5 6speed MT
Yesterday I removed my vaccum pump and I installed a vaccum pump delete kit, the brake booster is now connected to the manifold intake. I do notice a little difference in the brake assist I would say it's better. It's not a performance upgrade, I just wanted to get rid of my vacuum pump before it starts to leak. Installation is pretty easy, it's a bit long, I did a mistake by removing the vacuum cover, oil leaked over tools and it was a bit harder to manipulate, except that, the installation went fine.
I also noticed that the car is a bit more quiet on iddle, I don't know why, but the first time I started the car after the installation, a EPC light went on the dash and then disapeared a few seconds after. My friend also told me that the smoke from the exhaust was a bit more black than before, I don't know why too...
Anyway, here are a few pictures:
I bought Audi coil packs and NGK iridium spark, I will install it next week when I receive the package.
The next things I'm planning to buy it's the transmission and engine mounts pair sold by 034Motorsport.
I haven't been that much active on this topic before, so I'm just going to enumerate what I have done in the past months, changed the downpipe for a USP high-flow catalytic, changed cat-back for a TechtonicTuning exhaust with dual Borla tip (Sounds awesome, I will post some videos this week), tuned the car with UnitedMotorsport Stage 2, since the car is tuned it's make back-fire sound as hell each time I release the gas pedal, I'm not sure if it's normal. When I think about it, even if the manifold valve close, there is still a few O2 in the manifold and I don't think the gas is too rich since the car is tuned for 91 / 93 and I'm putting 91, so it's maybe a sparks that is not fully wokring as it should, well I will be able to confirm this soon, I'm replacing coil packs and sparks next week. It didn't make pop sound before the tune and before the tune, new downpipe and cat-back was already installed.
Edit: Finally I bought 034Motorsport engine-trans pair mounts today, I will install it next week too, is it hard to install ?
Old 02-10-2017, 07:49 PM   #69
MLue1
Thumbs up
Shouldn't be hard, just follow the instructions they give you.
Old 02-14-2017, 08:54 PM   #70
FlowMK6
FlowMK6's Avatar
Today, while I was waiting to receive my new coil packs and sparks, I decided to remove my current coil packs. I saw oil on my coil packs and called VW, they told me it's probably a leak from the valve cover gasket. So I wanted to order the gasket from my dealer and I have been told that it would take 3-4 days instead of 1-2 days because it's under revision by VW.
I was curious, so I made a few researchs and I found out that we should replace this gasket around 100k-130k milles and also that this gasket is most likely to leak compared to others gaskets. I'm going to install the new gasket next week and I will install my coil packs and new sparks, I will give you feedbacks next week too.
Just by precautions, I would recommend you to look if there is no oil on your coil packs and sparks since it seems to be a commun issue. Tuned cars seems to have higher chance for leaks since the pressure is higher.
