Old 10-16-2016, 03:06 AM   #1
$&cents
Drives: 2009 BMP GTI
Slowly losing power?
Hi all, 2010 GTI at 105k now. I have noticed that the car feels much slower than couple of years ago. When the boost kicks in I can still feel it but its rather weak. The DSG was changed out about a year ago under extended warranty with problem shifting, and so far I have no code. The car does make a grinding noise when I move from a cold start, but idle is smooth and there's no jerking.
Any idea? Could it be turbo? PCV? Leaky piston? What can I check to see to diagnose?
Thanks all!
$&cents is offline   Reply With Quote
Old 10-16-2016, 07:15 AM   #2
DarianBx3
DarianBx3's Avatar
Drives: 2013 MK6 GTI DSG
Have you ever had a carbon cleaning done?
APR Stage II Build Thread
DarianBx3 is offline   Reply With Quote
Old 10-16-2016, 10:23 AM   #3
FriggenT
Could the grinding noise simply be the surface rust that gets on the brake rotors while the car is still for a day or so? Even moisture in the air can cause that.
As far as power loss goes, I'd be with the guy above and ask if you've had the carbon cleaned?
Old 10-16-2016, 11:05 AM   #4
Changed the fuel filter? Spark plugs? Boost leak? Try the easy things first then an 'italian tune up,' then go for a carbon clean.
Old 10-16-2016, 11:27 AM   #5
$&cents
Carbon cleaning was done 10k ago at 034. How do I check for a boost leak?
Definitely not brake related. The grinding noise only happens when I am moving forward.
Old 10-16-2016, 12:57 PM   #6
FriggenT
If you don't know how, you can learn, BUT, it might be easier to take it to a shop for that simply because it's one of those things that if you don't have an air compressor and a boost leak tester it's a pita
Old 10-16-2016, 12:58 PM   #7
FriggenT
How was the carbon cleaning done? Walnut blasted?
Old 10-16-2016, 02:40 PM   #8
$&cents
034 removed intake manifold and did a proper scrub.
Old 10-16-2016, 04:35 PM   #9
m1k3_p
In my case it was the high pressure fuel pump. Car was sluggish for months , then rough idle and hesitating under load. After pump was replaced - back to normal. (Maybe even better )
m1k3_p is offline   Reply With Quote
Old 10-16-2016, 07:05 PM   #10
$&cents
The weird thing is the car idles just fine and I didn't get any code.
Old 10-16-2016, 07:47 PM   #11
FriggenT
So the plugs, coils, fuel filter, pcv, have all been checked correct?
Old 10-16-2016, 08:01 PM   #12
$&cents
Not yet. Those are good points and I will start from there. What's a good indication of a bad PCV? Condensation in the line?
Old 10-16-2016, 09:03 PM   #13
FriggenT
Well, there are so many from codes to oil around the pcv, build up around the filler neck. Some claim this doesn't work, but if you pull your dipstick out and you get no change in idle it's bad, if you open the oil cap and get no resistance, it's absolutely shot, there's some others, but I'd start there.
Old 10-16-2016, 10:59 PM   #14
Geryon86
Geryon86's Avatar
Drives: MK7 R
Sounds like you're bored of your K03.
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is online now   Reply With Quote
