Old 11-09-2016, 09:31 PM   #1
visceralsoup
visceralsoup's Avatar
Drives: 2013 VW GTI (sold), 2012 Golf Arrrr
Drivetrain shudder back.
Once again, I'm getting a very noticeable and harsh shudder whenever press on the accelerator and when I release the accelerator. I can't figure out what it is. I have torque solution engine and dogbone mounts as well as new LCA bushings. Anyone have an idea of what could be causing this?
2 MOJITOS, STAT!- Thad Castle
Turbo Ranger Build
visceralsoup is offline   Reply With Quote
Old 11-10-2016, 07:59 AM   #2
TimS
Drives: '12 Golf R
Rear driveshaft coupling?
Old 11-10-2016, 10:45 AM   #3
Drives: 10 GTI CSG DSG K04 4DR 130k+
Dual mass flywheel maybe.
Old 11-10-2016, 03:30 PM   #4
visceralsoup
Got under the car last night and confirmed. Rear couplng is torn. Getting it warrantied.
Turbo Ranger Build
Old 11-11-2016, 10:01 AM   #5
Mensurpj
Drives: Golf R
Sorry for the noob question, but where is this coupling located? Im having the same issue
Stage 2+ Golf R
Mensurpj is offline   Reply With Quote
Old 11-11-2016, 07:11 PM   #6
visceralsoup
Its directly in front of the rear differential.
Turbo Ranger Build
Old 11-11-2016, 07:12 PM   #7
visceralsoup
Turns out the coupler is NOT as bad as I thought. The tech drove with me and said the coupler is not what is causing the shudder. Im looking into rear differential mounts now. It feels like something has play and is shifting back and forth as gas is applied and let off
Turbo Ranger Build
Old 12-17-2016, 07:31 AM   #8
DUBlclutch
Drives: MK5 GTI 2.0T FSI 6MT & Golf R 6MT
Trans mount as well? How many miles on mounts? Any changes in set up just prior to shudder beginning?
Sent from my DROID4 using Tapatalk
DUBlclutch is offline   Reply With Quote
Old 12-17-2016, 11:29 AM   #9
justboostin
justboostin's Avatar
I have the same thing. I have upgraded the dogbone insert, motor and trans mount and I have a single mass flywheel. This happens when it first gear at around 5mph when you touch the gas and let off. The transition between those two states causes something to rock and sound loose. I'm wondering if it's the dogbone pendulum or if there is another trans mount I'm missing.
Sent from my SM-G925V using Tapatalk
justboostin is offline   Reply With Quote
Old 12-18-2016, 06:34 AM   #10
visceralsoup
No major changes. It seems to have gradually gotten worse over the past few months
Turbo Ranger Build
