Old 11-22-2016, 08:37 PM   #1
kthor703
kthor703's Avatar
Oil Pressure/Temp sensor solutions
Does anyone make a solution for both of these? I've seen an adapter from 42dd for oil pressure but nothing for temp.
I'm not interested in an external oil cooler at the moment, just want to monitor these items. I've seen sandwich plate adapters for the oil filter that incorporate temp/pressure sensors in them, but nothing for MK6s.
Old 11-22-2016, 09:06 PM   #2
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
You either weld bung on the pan for oil temp or you get this drain plug adapter.
https://www.ecstuning.com/b-new-sout...r-port/con022/
As far as oil pressure. There's the 42dd adapter you mentioned or there's the adapter from issam abed. Personally, I'd recommend getting the adapter from issam. It's a much better setup. I had the 42dd one and the rubber hose eventually broke down and started leaking.
CLICK HERE FOR MY BUILD
Cadubya is online now   Reply With Quote
Old 11-22-2016, 10:12 PM   #3
kthor703
kthor703's Avatar
What is the adapter from Issam Abed? Haven't seen this. Is it integrated with a sandwich plate?
Old 11-22-2016, 10:50 PM   #4
Cadubya
DUBYA
Cadubya's Avatar
It attaches to the alternator with a braided hose that goes to the hole where the OEM oil pressure sensor is under the oil filter and then you screw the OEM oil pressure sensor into the distribution block. Then you screw your aftermarket oil pressure sensor into the distribution block.
Old 11-22-2016, 11:29 PM   #5
kthor703
kthor703's Avatar
Wow, neat! I like that bracket. Did you just contact him to order through his site or is there a distributor? Do you have both of these? I track and wanted to watch pressure and temp. Was a little nervous about a sensor on the drain plug.
Old 11-22-2016, 11:51 PM   #6
Cadubya
DUBYA
Cadubya's Avatar
I actually tapped my pan where the OEM oil temp sensor would go if US cars came with one.
Old 11-22-2016, 11:53 PM   #7
Cadubya
DUBYA
Cadubya's Avatar
http://www.iabedindustries.com
Old 11-23-2016, 01:14 AM   #8
kthor703
kthor703's Avatar
Thank you for sharing! Appreciate the advice!
Old 11-24-2016, 03:29 PM   #9
kthor703
kthor703's Avatar
Do you track? What kind of temps/pressure do you see if so?
Old 12-07-2016, 12:28 PM   #10
kthor703
kthor703's Avatar
Bump. What pressure do you guys see? I see 22 when warm at idle and 40-50ish depending on RPM.
Old 12-07-2016, 12:36 PM   #11
mfractal
Drives: A3 8P Sportback 2.0T
40-50 psi I assume ? Sounds a bit low for high rpm situations. Should be around 60
Audi A3 Sportback 2010 2.0T DSG
CTS K04 @ GIAC HO + Intake + Boost pipes, APR DP + IC, Milltek Res Catback, Whiteline WALK & PU bushings, KW Street Comfort
mfractal is offline   Reply With Quote
Old 12-07-2016, 02:00 PM   #12
kthor703
kthor703's Avatar
Psi, yes. Haven't redined it yet, but I'm projecting there abouts. The APR OPS thread seems to suggest about 50 is what they saw in testing on a track.
Old 02-24-2017, 10:56 AM   #13
hbrown0509
hbrown0509's Avatar
Drives: 2013 VW GTI 4DR DSG
Found this thread after our discussion about oil temps on the other thread for Carbon buil-up. So did you have to do drilling intho he oils pan for mounting this? Also, I see you have an R32 belly pan as well. Any clearance issues with this. I also plan to get VWR springs installed at some point this spring, any ground clearance issues going this route?
Old 02-24-2017, 11:11 AM   #14
Cadubya
DUBYA
Cadubya's Avatar
I didn't have to drill into the oil pan, but I have a replacement oil pan. Some of the pans that came from the factory have the oil sensor hole welded shut rather than the bolt on cover. If that's the case you'd have to remove the pan and drill and weld a bung on or you'd have to buy the replacement pan with removable cover like in the link.
https://www.ecstuning.com/b-assemble...6j103600af2kt/
I don't have any clearance issues. My sender isn't lower than the subframe. It's going to depend on what the dimensions of the sender that comes with what ever gauge you choose though.
I have this VEI dual oil pressure/oil temp gauge.
http://www.veisystems.com/ws/oil-pre...e-monitor.html
