Old 12-28-2016, 02:20 PM   #1
Jcarollo765
Car overheating on track days...(Use distilled water or WaterWetter?)
What do you guys run on track days? Distilled water only or 50/50 w/ water wetter?
Thanks
Night Fury '13 Wolfsburg GTI/Carbon Grey/4-Door/DSG
Current Mods: APR K04 V3.2 & TCU V1.6//42DD DP//Unitronic Intake//H&R 26/24 Sways//Unibrace XB//SuperPro ALK//BSH Engine & Pendulum Mount//HPA 75a//Do88 Intercooler//H&R Cup Kit//Evo Boost Gauge//Soumatrix Speakers//BFI Stage 2 Tran Mount//GFB DV+//H&R 10/10 Spacers//Tyrol Brake Kit & Pads//Corgi Hair
Jcarollo765 is offline   Reply With Quote
Old 12-28-2016, 02:31 PM   #2
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
What are you're mods? What was the ambient temp? What gas are you running?
CLICK HERE FOR MY BUILD
Old 12-28-2016, 02:42 PM   #3
Jcarollo765
Most are in my sig: K04, D088 intercooler, cold air intake etc running 91 Octane.
Last time I was at Willow car would start to over heat toward the end of each session and outside temps were only 70f...
Old 12-28-2016, 02:56 PM   #4
Cadubya
DUBYA
Cadubya's Avatar
People have been having cooling problems with the k04 at the track. Probably because that turbo is way out of its efficiency range at tuned boost levels. Those tunes are fine doing a few rice rocket runs on the street, but repetitive lapping is a whole other story. Try running a higher octane with the 91 tune. Also, make sure your pvc is working correctly. If there's excessive blowby it'll dilute your octane rating and cause pinging or even worse detonation. Run some logs to see if it's pulling timing.
Old 12-28-2016, 03:26 PM   #5
Jcarollo765
Will do thanks Cadubya.
Do you have a more detailed build thread besides the one in your sig? Been debating going BT and impressed by the number your car is putting down out
Old 12-28-2016, 03:37 PM   #6
Cadubya
DUBYA
Cadubya's Avatar
Regrettably, I don't have a build thread. I just have my Wheelwell page. The link is in my sig. Don't get caught up on the dyno numbers. Different dynos produce different numbers. It's more about more reliable linear power delivery. BT is a huge commitment though. Especially if you piece your kit together rather than getting the off the shelf APR GTX kit.
Old 12-28-2016, 04:00 PM   #7
Jcarollo765
Did you go straight to BT or did you start off w/ a K04?
Old 01-07-2017, 02:56 AM   #8
ebuuz
ebuuz's Avatar
Drives: Mk6 GTI
You running the heater? It helped for me to have it on
2012 CW 6 speed. F23T on APR k04 v3.1, APR Carbonio, CTS turboback, Clutchnet 6 puck disc, 034 Street Density motor and transmission mounts, Hawk HPS 5.0, Motul RBF600, Newsouth boost gauge, DieselGeek SS
Dyno vid of my car
ebuuz is offline   Reply With Quote
Old 01-07-2017, 08:03 AM   #9
Cadubya
DUBYA
Cadubya's Avatar
I was k04 before BT.
Old 01-09-2017, 12:42 PM   #10
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
I read somewhere that the water wetter stuff will rust your engine and radiator.
mamock116 is offline   Reply With Quote
Old 01-09-2017, 02:01 PM   #11
red_stapler
red_stapler's Avatar
Drives: '12 GTI DSG
That's the opposite of my understanding. Running straight water will cause corrosion because you're missing the anti-corrosion components of the coolant. Adding water wetter to straight water would prevent that.
As an anecdote, someone on nicoclub tested it:
http://forums.nicoclub.com/diy-test-...s-t146241.html
'02 Civic Si
Formerly: 12 GTI DSG
Old 01-09-2017, 09:27 PM   #12
Have you removed the hood weather strip by the wipers and insulation? I found that will dissipate much of the heat. Also try wrapping the intake pipe above the exhaust manifold. Lastly, I have a modified street shield that helps with airflow. I ran my k04 car pretty hard at VIR for 30 min stretches, DSG even, with no issue.
Old 01-09-2017, 10:40 PM   #13
red_stapler
Drives: '12 GTI DSG
If his coolant is overheating you don't want to reduce airflow through the radiator like that.
'02 Civic Si
Old 01-09-2017, 11:45 PM   #14
mraaf
Drives: 2011 MK6 GTI
^Sub^
REVO 3
mraaf is offline   Reply With Quote
