Old 08-28-2017, 02:20 PM   #43
Tony48
Tony48's Avatar
Picked up a set of used OZ Ultraleggera's (18x8 ET45) and stud conversion from Motorsport Hardware.The hardware seems top notch. I'll be putting it all on the car within a week.
Old 08-29-2017, 01:00 PM   #44
GoodTimesIndeed
GoodTimesIndeed's Avatar
Drives: 2011 GTI 2Dr DSG
Those wheels are gonna look great! Hopefully you have better luck with colored lugs then I did. I ran a set of red ones (different brand) and after a few months they were all pink and faded.
Old 08-29-2017, 01:30 PM   #45
Tony48
Tony48's Avatar
Thanks man! I saw those lugs on your build thread. Your experience swayed me to purchase steel lugs as opposed to aluminum. Anodized aluminum is subject to fading, especially when manufactured poorly. I think this set will last but only time will tell I suppose. I like the idea of forged steel versus aluminum solely from a strength standpoint as well.
Old 08-30-2017, 03:19 AM   #46
focusfuri75
Nice build, but I can't seem to find those lug nuts you bought on the Motorsport hardware website.
focusfuri75 is offline   Reply With Quote
Old 08-30-2017, 09:07 AM   #47
Tony48
Tony48's Avatar
Here's a link to the lugs I purchased: 17mm MH Titan Cold Forged Alloy Steel Race nuts
Just a heads up, the lugs at that link are on clearance because they're not threaded all the way through so they can only be used with studs up to 68mm. They also offer through-threaded lugs.
Old 08-30-2017, 05:40 PM   #48
focusfuri75
Thank you
Old 08-31-2017, 12:36 AM   #49
gdub09
gdub09's Avatar
Drives: GTI DSG
Nice build! Get rid of the lug nuts though. The paint strips pretty quick unless you put rag on em or something. I had the same kit on my MK5 and loved it but the paint started chipping off within a month. I ended up just get open ended ball seat lug nuts. My only concern was trying to find a set of locking nuts. As for the studs, I cleaned out the holes and coated em in red loctite. Never had an issue of any of em coming loose.
Old 08-31-2017, 09:05 AM   #50
Tony48
Tony48's Avatar
Thanks for the info. I already picked up a set of black, open-ended lugs as backup. Since I already have the MH extended lugs I might as well run 'em until they're ugly. The idea behind purchasing the extended lugs was to help protect the otherwise exposed stud from corrosion and road grime. I guess that may not be a problem since I see plenty of guys running fully exposed studs.
Old 08-31-2017, 10:29 AM   #51
gdub09
gdub09's Avatar
Drives: GTI DSG
I'd coat em in a some sort of metal corrosion protector. Mine had surface rust after a few months. I cleaned em after a while and they seemed to stay clean. Idk if it was just my set or their product in general. But it wouldn't hurt to put a protector on em just in case.
Old 09-06-2017, 02:39 PM   #52
Tony48
Tony48's Avatar
Before & After shots:
IMG_20170901_183238 by Tony G, on Flickr
IMG_20170901_184445 by Tony G, on Flickr
IMG_20170901_183058 by Tony G, on Flickr
IMG_20170901_203719 by Tony G, on Flickr
IMG_20170901_203747 by Tony G, on Flickr
IMG_20170901_203925 by Tony G, on Flickr
Old 09-07-2017, 02:47 PM   #53
gdub09
gdub09's Avatar
Drives: GTI DSG
Lookin good!!
Old 09-11-2017, 09:52 AM   #54
Tony48
Tony48's Avatar
I've started piecing together my DIY RSR clutch. I've ordered all fasteners, metal TOB, clutch disc, and a gently used DMFW. I'll order the TTRS pressure plate and oil soon. The plan is to get this thing on the car sometime this winter once I have access to a lift. I also plan on replacing the whole timing system this winter. Bye bye $$$$
IMG_20170510_211409 by Tony G, on Flickr
Old 10-29-2017, 07:42 PM   #55
Tony48
Tony48's Avatar
Replaced my K&N intake with an IE intake. There really wasn't any reason except that I wanted a new look under the hood and someone local had it for sale. K&N intake is For Sale Here if anyone is interested.
IMG_20171029_141121 by Tony G, on Flickr
IMG_20171029_141128 by Tony G, on Flickr
Also pulled out my soundaktor & control unit from under the windshield cowl. I had previously unplugged the control unit but was recently getting some rattle and noise from under the dash near the soundaktor. I decided to remove the wipers & windshield cowl to fully remove it and tape/ziptie up the electrical connections. We'll see if it gets rid of my rattle.
IMG_20171029_115942 by Tony G, on Flickr
IMG_20171029_141920 by Tony G, on Flickr
Old 11-09-2017, 11:05 AM   #56
Tony48
Tony48's Avatar
ECS Ultimate Timing Chain kit has been purchased along with a new lower timing cover. This will get tackled over the winter.
