Old 01-11-2017, 03:25 PM   #1
Vengeance
Vengeance's Avatar
Drives: 2010 GTI Base
Exclamation Oil leaks on both sides of the block...
So I recently pulled the panels off of the passenger wheelwell to get a look at the Timing Chain Tensioner and I found a large amount of oil. So after I looked around a bit and took some pictures, I decided to look around to see if I could see any oil anywhere else. It looked like there was some oil coming out of one of the turbo bolt holes, and where the Transmission meets the Block
I have had some people suggest it is the cam holder gasket and the upper and lower timing chain cover gasket and the rear main seal and that I have a blown turbo (No smoke that I can see though).
Do these things that they have suggested make sense or am I looking at something else?
Pictures:
2010 Carbon Steel Metallic GTI - DSG
R8 Coil Packs
Vengeance is offline   Reply With Quote
Old 01-11-2017, 03:47 PM   #2
beauy46
Drives: MKV TR GTI
how many miles on your car? Check this thread for the upper timing chain gasket
http://www.golfmk6.com/forums/showthread.php?t=85417
This oil leak can lead to waterpump failure. The hot oil drips on the plastic water pump housing causing it to deform and spring a leak.
beauy46 is offline   Reply With Quote
Old 01-11-2017, 04:03 PM   #3
Vengeance
Vengeance's Avatar
Had the water pump replaced 6 Months ago under warrentey when I bought the car. I didn't realize how bad it was because the dealership I bought the car from, cleaned the oil off of the block before they sold it and after they replaced the water pump...
R8 Coil Packs
Old 01-12-2017, 09:55 AM   #4
vwgti2.0t
Drives: 2011 CW GTI
The upper cam girdle/valve cover seal is not a gasket, just sealant (green). But I'd assume that's where the oil is coming from on top.
The oil on the lower timing cover looks to be coming from behind the crank pulley, which would mean the crank pulley seal in the timing cover is bad. Since you have a 2010, I'd just buy the cover and a new tensioner and kill two birds with one stone.
Most tensioner update kits also include the upper timing cover (plastic piece) gasket, which looks to be leaking as well.
If the rear main seal is leaking you'll see it coming out of the weep hole in the bottom of the trans where it meets the engine block. You didn't include pictures of this, so I don't know if that's where it's coming from or not.
Finally, I'd check the PCV. All of these leaks would have me curious as to if the PCV went bad and overpressurized the crank case, ruining all of these seals.
Old 01-12-2017, 11:13 AM   #5
Vengeance
Vengeance's Avatar
Thank you for all of this info. I have a lot of things to work on I see. I ordered the Timing Chain Replacement Kit this morning so I am starting there.
R8 Coil Packs
Old 01-12-2017, 05:48 PM   #6
akebonogti
Drives: GTI 6MT
How many miles on it?
akebonogti is online now   Reply With Quote
Old 01-13-2017, 07:18 AM   #7
simpson110
Drives: 2013 gti
I would check the pcv before you get too involved replacing gaskets. If it's had and the crankcase is over pressurized you will be throwing money away when you blow all the new gaskets you put in.
Mods: cts ko4 w/ apr v3.1, gfb dv+, HS tuning rsr, ttrs bbk, spm intercooler, dg springs, bsh race intake, spm catless dp, cts cb, nsp redline boost gauge in vent pod, vacar led tails, vagcom tweaks
Pm me for vagcom in southern ct(near new haven)
simpson110 is offline   Reply With Quote
Old 01-13-2017, 11:40 AM   #8
Vengeance
Vengeance's Avatar
74,000 - Just hit it about an hour ago lol
R8 Coil Packs
Old 01-13-2017, 11:42 AM   #9
Vengeance
Vengeance's Avatar
I will have to look, Is there a rebuild for this if it has failed, or do I have to replace it outright?
R8 Coil Packs
Old 02-11-2017, 12:58 PM   #10
Vengeance
Vengeance's Avatar
It looks as though this has been replaced at some point. This is a 10 Car, and it has revision E instead of just A with no letters after it.
After some research, it appears as though the latest revision is AH
R8 Coil Packs
Old 02-11-2017, 01:53 PM   #11
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
Pcv's go bad at irregular intervals. Could be a month, could be years. They are crap and poorly made. I'd replace the pcv and brake clean the F out of the entire engine and get it clean. Then reassess.
CLICK HERE FOR MY BUILD
Old 06-27-2017, 01:24 AM   #12
italiansanto
Drives: GIAC Stage II 2011 GTI
I'm having a similar problem as well in my 2011 GTI with 89,000 miles. What was the final solution to the problem?
italiansanto is offline   Reply With Quote
Old 06-27-2017, 04:58 AM   #13
BudgetPhoenix
Drives: 09 GLI
I agree with trying this first!
