Old 03-05-2017, 05:03 PM   #1
golf 6
golf 6's Avatar
Drives: golf5&6
Flashing glow plug light
Hi all as the title says this is a question about the glow plug light on the dash flashing when driving with a ! At the bottom of the mfd where your miles would be. There is no loss of power or anything else just the light flashing. If yu stop the car and switch it off then back on it goes out. What is causing this?
Isit just a glow plug on the way out or something more worse?
Thanks
Sent from my SM-G900F using Tapatalk
golf 6 is offline   Reply With Quote
Old 03-09-2017, 10:19 PM   #2
jedimk6bgp
jedimk6bgp's Avatar
Drives: MK6 TDI Blue Graphite Pearl
I had that on mine..... It ended up being the egt temp sensor pre turbine( before turbo) easy repair if no dpf..... If dpf is still on its a bit tricker as the dpf is in the way
jedimk6bgp is offline   Reply With Quote
Old 03-15-2017, 05:22 AM   #3
golf 6
golf 6's Avatar
Drives: golf5&6
Thanks. Did u use a DIY guide or was it as easy as...123
