Old 03-10-2017, 10:43 AM   #1
AngstyPotato
AngstyPotato's Avatar
Drives: 2011 MK6 GTI 6MT
Track Newbie
So I've never done a track day but I'm looking to go real soon.
Anything I should know / need?
2011 MK6 GTI 6MT | APR Stage II ECU | APR Carbonio Intake | RSR Clutch | APR Downpipe | Magnaflow CBE | R8 Coils | Alzor 010 | ECS Spacers | ECS Slotted Rotors | EBC RedStuff Pads | Smoked Side Markers | PIAA Ion Yellow Fogs
AngstyPotato is offline   Reply With Quote
Old 03-10-2017, 12:34 PM   #2
red_stapler
red_stapler's Avatar
Drives: '12 GTI DSG
The basics:
Sunscreen
Cooler w/ water & lunch
Shade (hat, umbrella)
Close-toed shoes
Long pants
Long sleeve shirt*
Helmet*
Bleed brakes / flush brake fluid if old
* - You'll want to check with your trackday group about specifics here
'02 Civic Si
Formerly: 12 GTI DSG
Old 03-21-2017, 01:51 PM   #3
Jcarollo765
Thumbs up
https://driver61.com/resources/track-day-guide/
Have fun, talk to other drivers, study the course.
Night Fury '13 Wolfsburg GTI/Carbon Grey/4-Door/DSG
Current Mods: APR K04 V3.2 & TCU V1.6//42DD DP//Unitronic Intake//H&R 26/24 Sways//Unibrace XB//SuperPro ALK//BSH Engine & Pendulum Mount//HPA 75a//Do88 Intercooler//H&R Cup Kit//Evo Boost Gauge//Soumatrix Speakers//BFI Stage 2 Tran Mount//GFB DV+//H&R 10/10 Spacers//Tyrol Brake Kit & Pads//Corgi Hair
Jcarollo765 is offline   Reply With Quote
Old 03-21-2017, 02:01 PM   #4
jay745
jay745's Avatar
You want to at the minimum flush your brake fluid with some high temp fluid. Keep a close watch on your brakes, be aware of how they feel and if the pedal starts to fade then tone it down a little. Going on track with oem pads and fluid is not advisable even if you're just testing the waters.
Old 03-23-2017, 10:49 PM   #5
George11
Drives: VW GTI 2011
Don't forget a chair and torque wrench to retighten your lugs.
Sent from my SM-G935P using Tapatalk
My Build Thread ⧸ APR Stage 2 ⧸ RSR Clutch ⧸ Wavetrac LSD⧸ 42 Draft Design downpipe ⧸ Koni Coilovers
George11 is offline   Reply With Quote
Old 03-24-2017, 01:25 PM   #6
darkGTI
Drives: VW GTI MK6
Make sure your pads have more than half way thick, also make sure your tire pressures are good, and that tires don't rub anywhere if you're not running oem setup.
APR Stage 2|Unitronic Custom Intake|R8 Redtops|HPA SS|SPULEN Coilovers|SPM 3'' CBE|AWE Downpipe |034Motosports CatchCan|Unibrace XB|Unibrace UB|GFB DV+|Neuspeed TOP|BSH TBP|Godspeed IC|HSTuning RSR clutch|Wavetrac LSD |Fluidampr Crank Pulley|Polar FIS|PTP Turbo Blanket|H&R Sway Bar 26mm front sway bar|034Motosports 25.4mm rear sway bar|TyrolSport Front and Rear Deadset|NSQBBK|SuperPro
darkGTI is offline   Reply With Quote
Old 04-09-2017, 12:53 PM   #7
Short Bus
Drives: '10 GTI
If this is your first track event focus entirely on safety items. Do not concern yourself with speed, focus on learning (from your instructor) how to safely operate your vehicle on a track. To prepare for following track events work on changing things that'll allow your car to deal with heat better (tires, brakes, etc).
For a first track day I think these things are critical:
1. inspect your brake lines, if your 2011 has the originals you may want to replace them with new OEM lines
2. flush brake fluid. Fresh OEM brake fluid will be sufficient.
3. check pads, if there's any question as to how much life they have get new ones.
4. inspect rotors for micro-fractures or any cracking, replace if necessary.
5. test drive, if rotors are "warped", as in there's pulsing through the peddle that is not ABS engagement, get the rotors turned (if within spec, I prefer brand new to turning) or replace them
6. inspect tires, replace as necessary.
I'm a huge fan of speed bleeders on the brakes. These will let you take a pump or two of fluid out of each caliper in between sessions as necessary or at the end of the day by yourself and with the wheels on.
Throughout the day perform a basic visual inspection after each session; oil, coolant, brake fluid, tire condition & air pressure. Have a close look at each sidewall and if you feel that the tire is rolling over too far, add air pressure. If you're running even a basic sport tire like a Bridgestone RE760 the sidewalls should be stiff enough that your "hot" pressures should be fun at somewhere under 40 PSI, but if you're running all seasons you may need to add more to keep it from rolling over.
Old 05-13-2017, 05:48 AM   #8
schulmann
Drives: Golf GTI
The MK6 is castrated by the brakes, you need to work on a cooling system.
My home is www.viperacr.com
schulmann is offline   Reply With Quote
