Old 03-16-2017, 04:49 PM   #1
somerset9
somerset9's Avatar
Drives: 2014 GTI 6MT Wolfsburg Edition
Cleaning out Carbonio air filter
Hi. I have a APR Carbonio intake and thinking of cleaning the filter...should have done it before I got it installed but here we are.
What is the easiest way to get the filter out? I've removed my bumper a couple times so if it comes to that I'll just have to take an additional 30 minutes or so, but just thought I'd ask.
Thanks!
2014 GTI 6MT Wolfsburg Edition | DG Short Shifter | Torque Solution billet pendulum insert | BFI Heavyweight Knob | Bilstein Sport + Eibach Sportline | Eibach 23mm RSB | EuroSport rear hatch brace
somerset9 is offline   Reply With Quote
Old 03-17-2017, 05:58 AM   #2
Squashdaddy
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
I remove the closest hose clamp on the coupler, then remove the two screws that hold the intake to the front of the car. Slide/push the coupler off of the pipe and the body and pipe should come right out. Remove the 4 screws on the back of the body and pull the filter out. Hope that all makes sense.
Old 03-17-2017, 11:28 AM   #3
somerset9
somerset9's Avatar
The 2.5 and the TSI use different intakes. The CAI for the 2.5 has the filter right in front of the driver's wheelwell. Cannot be accessed directly from opening the bonnet.
Old 03-17-2017, 01:48 PM   #4
erichorn10
Drives: 2010 2.5L Sportline.
I usually jack up the drivers side front and either remove the wheel or just crank it all the way to the passenger side. Remove the front piece of the wheel well liner and the filter is right there. If there's an easier way I'd also love to know, but this is how I have been doing it.
erichorn10 is offline   Reply With Quote
Old 03-17-2017, 03:52 PM   #5
somerset9
somerset9's Avatar
If I can just remove the front wheel well liner without jacking it up, it doesn't seem too bad. I'll try that first and then start jacking things up or removing the bumper as it becomes necessary.
Old 03-18-2017, 01:58 AM   #6
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Couldn't you just remove the belly pan (which is easy) and then reach up & access it from underneath?
2017 Passat VR6
2017 Passat R-line
Old 03-18-2017, 03:10 PM   #7
somerset9
somerset9's Avatar
Need some vertical room to loosen the hose clamp.
I just ended up removing the bumper. Done it a few times,s o it's just going through the motions for me. I just hope I don't lose any more screws
