Old 11-01-2010, 06:42 PM   #1
James9449
James9449's Avatar
Drives: 2011 GTI, DSG, United Gray
Unhappy A map for fusebox ?
Does anyone have a schematic of the fuse panel behind the lower left dash in the MKVI GTI -- or know where I can obtain one ? I'm having difficulty troubleshooting fuse failure, because identifying a blown fuse requires pulling each one to determine failure. I need a map. Or a brain transplant. Help.
2011 UG GTI 2-door; DSG; Autobahn; Bi-Xenons; Lamin-X front end; Geo-Shield tint (50%); Borla cat-back; full APR Carbonio intake; APR Stage 1 ECU; LED interior lighting; Neuspeed 25mm RSB; BSH motor / transmission / pendulum mounts; BSH catch can with 42dd drain kit; P3 vent-mount digital boost gauge; EuroSwitch; LED city lights; R1 Concepts Premium slotted / drilled rotors; PosiQuiet ceramic pads; VW DG linear springs; misc. cosmetic stuff.
James9449 is offline   Reply With Quote
Old 11-01-2010, 06:44 PM   #2
danielj
danielj's Avatar
Drives: 2013 BMW x135
I haven't looked in the owners manual in awhile but shouldn't there be a diagram?
Old 11-01-2010, 08:48 PM   #3
James9449
James9449's Avatar
DanielJ -- In the 350+ page manual that came with my 2011 GTI -- a thick little book which, by the way, describes lots of features that my little GTI does not even have -- has no such schematic. There is a small matrix near the end of the book, but it only provides color coding of the fuses by amperage -- hardly even necessary. The rest of the content on fuses gives is a description of how to pull a fuse and how to identify a fuse that's blown. Again, hardly necessary. So unless I can get hold of a tech service manual or something that features a fuse map, finding the offending fuse is kind of a tedious pull-and-examine drill. I've not seen a shop manual for an MKVI. Where could I find one? I dunno.
Old 11-01-2010, 10:29 PM   #4
danielj
danielj's Avatar
You sound really frustrated.
I went and checked my owners manual. While large, if you exercise common sense its logically laid out. Looking in section 3.3, Tips and Advice, pages 95 an 96, you'll see fuse box maps with the fuses purpose and slot #.
You're making a simple task overly complicated.
Old 11-01-2010, 11:41 PM   #5
pbm317
Drives: 2010 GTI 5 Door
I can share the frustration. While I've seen the "map" in the manual, mine doesn't seem to line up with the actual box itself.
pbm317 is offline   Reply With Quote
Old 11-02-2010, 11:43 AM   #6
dsm1983
Drives: ...
All things considered, identifying a blown fuse is a very simple process.
Unless you're blind.
dsm1983 is offline   Reply With Quote
Old 04-25-2011, 10:35 PM   #7
lopedawg
Drives: 2011 GTI 4DR w/sunroof black
[quote=James9449;125875]DanielJ -- In the 350+ page manual that came with my 2011 GTI -- a thick little book which, by the way, describes lots of features that my little GTI does not even have -- has no such schematic. There is a small matrix near the end of the book, but it only provides color coding of the fuses by amperage -- hardly even necessary. The rest of the content on fuses gives is a description of how to pull a fuse and how to identify a fuse that's blown. QUOTE]
+2
Im guessing there was a change for the 2011 user's manual. I've looked at my entire book and there is no diagram for the fueses.
lopedawg is offline   Reply With Quote
Old 04-25-2011, 10:45 PM   #8
CGTI
Drives: 2010 Carbon Steel Autobahn
try this
http://www.golf********.co.uk/index.php?topic=178454.0
CGTI is offline   Reply With Quote
Old 04-28-2011, 07:18 PM   #9
lopedawg
Originally Posted by CGTI View Post
Thanks
Old 12-24-2011, 10:23 PM   #10
Tecni
Tecni's Avatar
Drives: 2010 Volkswagen GTI
My inner tail lights aren't working. I'm certain the fuse blew but I can't find it...
My fusebox looks NOTHING like the one on that diagram.
picture:
2013 Golf R for sale!
Tecni is offline   Reply With Quote
Old 12-25-2011, 11:39 AM   #11
Tecni
Tecni's Avatar
Problem solved
Old 12-25-2011, 12:30 PM   #12
awkwardbeta
awkwardbeta's Avatar
Drives: 2012 VW GTI Autobahn
If you still didn't get your hands on a fuse map or solve your problem yet, try using a DMM (digital multimeter) and test for continuity using the needle-like probes. It's faster and more reliable than pulling each one out and looking to see if it's blown (sometimes the blown fuse is so clean that it's hard to tell).
Super simple: turn your DMM on to test continuity, and to test how it works, touch your red and black probe ends together. You should hear a *beeeep* letting you know that there's continuity, ie. you have a complete circuit running from one probe to another.
Now go to your fuse box. If you look at your fuses, you'll see two tiny exposed fuse leads, one on each side of the amp number (15, 20, 30, etc.).
The fuse leads are tiny, just big enough for your DMM probe. Touch one fuse lead with the red probe and the other fuse lead with the black probe. Doesn't matter which probe goes to which lead. If your fuse isn't blown, you'll hear a beep. If it is blown, that means there's no continuity, and you've found your culprit.
You can go through all your fuses using this method in under a minute. Auto techs use this method all the time to test possible blown fuses.
2012 VW GTI. 4-door, Autobahn, Carbon Steel Gray
MECP Certified Autotech | www.awkwardbeta.com
"You know what the chain of command is? It's the chain I go get and beat you with until you know who's in ruttin' command here." - Jayne Cobb
awkwardbeta is offline   Reply With Quote
Old 12-25-2011, 04:17 PM   #13
Carbon Steel
Carbon Steel's Avatar
Good info on testing fuses, thanks awkwardbeta.
peace
Old 12-25-2011, 07:27 PM   #14
el_zorro
Drives: 11-GTI
These guys have a fuse map that is closer to my 2011 GTI Autobahn
http://www.golf********.co.uk/index.php?topic=200792.0
el_zorro is offline   Reply With Quote
fuse, identification, map, schematic
